Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Replace taillights
    JD2004 is offline Cadillac Owners Fanatic
    Automobile(s): Base 2007 Escalade EXT, 04 Cadillac SRX V8
    Sep 2007
    Oklahoma
    271
    Replace taillights
    First of all, this is a great forum!
    Im currently working on getting my SRX registered in Norway. I`ve brought it with me from Colorado. The DMV tells me that I need those amber export-style taillights. Fortunately, I dont need rear foglamps. I was gonna try to do most of the job of replacing the taillights myself. Ill leave the wiring to the dealership.
    I guess the hardest part is to remove the inner panels. Anyone done this job before? I could really need some help here! thanks!
    Autobahn_Burner is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac SRX
    Mar 2007
    Germany
    121
    Re: Replace taillights
    See your e-mail inbox for my proposal...
    srx2005 is offline Cadillac Owners Member
    Automobile(s): 2005 SRX V6 AWD; 2000 Eldorado ETC
    Feb 2007
    South Jersey
    83
    I also need to remove the rear inner panels to access the tail light so I can replace a bulb (side marker). Does anyone know how to do this?
    Also, I couldn't loosen the nut that holds the upper seat belt bracket (near roof) - is there a trick to loosening it or it is just very tight?
    Thanks for the help.
  5. #4
    tobaksankan is offline Cadillac Owners Member
    Automobile(s): SRX 2005 Europe
    Jun 2009
    47
    14
    Hi I need to remove the left taillight as well. Seems to be grounding problem since a few leds are malfunctioning, with a faint light some times.
    please advise me how to remove it - and if u know - can a single led be replaced (or I have to spend 1200 dollars to get a new taillight?)
  6. #5
    Sep 2007
    Oklahoma
    271
    tobaksankan, You got to remove all the sidepanels from the rear door and back, seatbelt and some of the rear fan assembly (if you have one) to access taillights. It is a lot of work. search ebay for new taillights and save major $s.
    The bolts for the seatbelt is really tight, btw. Im pretty sure you`re going to need some torx-tools. You got to remove the entire taillamp, individual leds can`t be replaced.
    good luck!
  7. #6
    Jun 2009
    47
    14
    I got a used tail light so now Im ready to go. Thx JD!
    But it seems really tricky with the seatbelt. Would u recommend I do it myself?
    Autobahn - Is there anything more you would add to JD:s instruction?
    Best
    Anders
  8. #7
    Sep 2007
    Oklahoma
    271
    The seatbelts are not that difficult, though really tight. I`d say getting the panels off without damaging them is the hardets part. I you have a warm garage, time, and some torx tools, i would give it a try.
  9. #8
    kenmesita is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Dec 2007
    Was anyone successful in replacing the rear tail light? I have a 2008 5 pass. SRX (no 3rd row seat) with a broken lense. At what point do you start removing the trim and how hard is it? Is there a Manual or Service Guide available?
    Thanks
  10. #9
    Sep 2007
    Oklahoma
    271
    I succeded in replacing the taillights....I had to remove panels to access screws that hold the entire light in place. You will have to remove/replace the entire light if you have a broken lense.
  11. #10
    Jun 2009
    47
    14
    I ended up letting a technician putting them in... Easy but expensive... The removal of the seatbelts made me hesitate... so I whimped out.
    However, I have replaced the licence plate bulbs - which was really easy - and will replace the HID blubs which does not seem so difficult as people say.
    (Funny that replacing bulbs on a car should be considered as an achievement - when it should be designed for grandma to fix)
  12. #11
    PJ1520 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 SRX4 N*, 2004 Infinity G35 Coupe
    Feb 2010
    New England
    2,005
    While we are on the topic of rear bulb replacements, I have a few "out" on one side for my top rear hatch brake lights. I have been doing unsuccessful searches on this forum for recommended ways to replace these, and with a long(er) lasting replacement of them all.
  13. #12
    jsiddall is offline Cadillac Owners Fanatic
    Automobile(s): 09 SRX V8 AWD Sport, 06 STS V8
    Oct 2009
    Ottawa, Canada
    43
    159
    Quote Originally Posted by PJ1520 View Post
    I think all the rear lights are LEDs and are not serviceable. You likely need to replace the whole assembly.
    The best I have been able to find for the large filament bulbs (ex: DRL/turn signal) is the "LL" version. Still not great though.
    I have replaced one of the 194 type marker bulbs with an LED version. The problem is they say those won't last long when used inside an enclosure with other high power bulbs (like the headlamps). So far so good. Time will tell.
  14. #13
    Feb 2010
    New England
    2,005
    Quote Originally Posted by jsiddall View Post
    Thanks, JS. I failed to check these out when I took delivery on my 07 CPO back in January, and my SIL noticed four consecutive bulbs in a row were out, starting at the far left of the brake light bar on the top of the hatch. Four in a row sounds strangely coincidental like it isn't the bulbs. Think I will give my dealer a call and run it by them......nothing ventured nothing gained.
  15. #14
    carguy2006 is offline Cadillac Owners Member
    Automobile(s): 04 Seville & 2 Corvettes 69 & 07
    May 2006
    Fremont, CA
    99
    I understand if the car is still in warranty all lights are covered....
  16. #15
    Feb 2010
    New England
    2,005
    Quote Originally Posted by carguy2006 View Post
    It is.....original warranty is in effect, plus my vehicle is CPO with the factory warranty extension. I'll give it a whirl.
  • You may not post replies
