Results 1 to 9 of 9
Thread: Best oil to use?
    Nov 2004
    5
    Best oil to use?
    I am on a trip and need to add oil to my 2006 SRX Northstar engine. What is the best type to use? I am in the northeast, so fall is approaching. Conventional or synthetic?
    MortnCyn's Avatar
    MortnCyn is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 N* Thunder Gray/Ebony AWD/NAV/MRC
    Mar 2004
    Illinois
    81
    875
    Re: Best oil to use?
    It comes with Mobil One synthetic. Would not mix with other brands and certainly not with regular oil. Do you know what oil is in it now?
    Nov 2004
    5
    Would it say it on the work order from my last oil change at the dealer?
  5. #4
    MortnCyn's Avatar
    Mar 2004
    Illinois
    81
    875
    Quote Originally Posted by mazzam View Post
    It might. If not, it would seem logical that they would only put Mobil One in the N* V8 unless you told them to use something else. If nothing else, the price for a Mobil One change will be anywhere from $45 to $85 dependent on the area and your dealer.
  6. #5
    RobVuk is offline Cadillac Owners Fanatic
    Automobile(s): 2008 SRX V8 AWD Sport
    Oct 2007
    Nashville, TN & Chicago
    196
    It is ok to mix Mobil One with regular oil. There is no reason to use anything but Mobil One. I believe it is suggested in your manual and it comes with it from the factory.
  7. #6
    Nov 2004
    5
    THANKS to all...
  8. #7
    G32006SRX's Avatar
    G32006SRX is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Cadillac SRX V6 AWD
    Aug 2008
    Cleveland, OH
    293
    I have a 2006 V6. I looked at the owner's manual and have the oil fill cap that says Mobil 1. According to the manual this is the v8 Cap.
  9. #8
    c5 rv's Avatar
    c5 rv is offline Cadillac Owners Connoisseur
    Automobile(s): 91 Allante (gone), 06 SRX (gone)
    Jun 2003
    Michigan
    4,396
    Whatever oil you use, just remember to check it. I usually have to add a quart to my 3.6 when the OLM drops below 50%. I loaned the car to my sister and brother-in-law for three weeks. When I checked the oil this weekend, the OLM was at 44% and I needed to add just under a quart.
  10. #9
    louisn's Avatar
    louisn is offline Cadillac Owners Fanatic
    Automobile(s): 2004 srx V-8 awd
    Jan 2005
    arkansas
    482
    Use only GM approved synthetic. There are only a few. I think I remember the manual said if anything else is used, remove ASAP. Use anything else you may have a warranty problem if the dealer knows. I also have a vague recollection that someone put the wrong oil---was not synthetic or the wrong type synthetic--in their engine and had to undergo several very quick oil changes in succession to get it out.
  • You may not post replies
