AWD and Traction Control are they the same
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, AWD and Traction Control are they the same in Cadillac SRX / XT5 Forums; I am in the process of purchasing a 2004 SRX which has the traction control button in it, does that ...
    hacketjoe is offline Cadillac Owners Member
    Automobile(s): Cadillac
    May 2008
    I am in the process of purchasing a 2004 SRX which has the traction control button in it, does that make it AWD?
    King3244 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 SRX
    Oct 2005
    347
    Re: AWD and Traction Control are they the same
    No....
    c5 rv's Avatar
    c5 rv is offline Cadillac Owners Connoisseur
    Automobile(s): 91 Allante (gone), 06 SRX (gone)
    Jun 2003
    Michigan
    4,396
    No. The traction control button disables the throttle interrupt when slippage is detected. It is useful when taking off from loose or slippery surfaces - like pulling out of a gravel driveway onto a 50 MPH road. My RWD SRX also has a traction control button.
    TSS's Avatar
    TSS
    TSS is offline Cadillac Owners Connoisseur
    Automobile(s): 07 Lade & 06 SRX (Gone); 2010 Enclave CXL; 2010 MKS Ecoboost
    Jun 2006
    3,673
    NO. ALL have traction control.
    laserguy's Avatar
    laserguy is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac Escalade AWD Lux
    Dec 2007
    Canada
    45
    108
    Do your homework...before you buy it !
    All comes with traction control...
    AWD is sort of 4x4 all the time and not all comes with
    Magnetic Ride is other feature and not all comes with
    Laserguy
    Northern SRX's Avatar
    Northern SRX is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 CTS-4 3.6 & 2008 SRX-4 V6
    Nov 2006
    Ottawa, Canada
    950
    just to chime in along with the others. The SRX traction control is an all-speed system that's pretty decent - it detects wheel slippage and adjusts brake and throttle to ensure proper tire traction. SRX's "Stabilitrak" system also compares driver steering input with the angle it is actually turning (the "yaw") and, using brake and throttle, makes adjustments even before forward wheel slippage occurs.
    So, it's a very advance system and not to be confused with what passes for traction control on a lot of lesser vehicles. Still, it's no AWD.
    There are three ways of determining whether an SRX has AWD and (IMHO) - the most definitive is having a dealer run your VIN through to see what it has. There are also the RPO codes (located in the back - mine are on a sticker underneath the cover for the 3rd row headrests and jack. On my '04, the AWD code is MX7 but I understand that others say MX5. If either of these codes is on your sticker, it's extremely likely that yours is AWD.
    You can run your other RPO codes through this RPO look-up to see what else is on your vehicle.
    The third way is to get two SRX together - as long as you can detect a significant difference in the size of the front passenger's footwell, then the one with the smaller footwell is likely to be the AWD. I have never heard of an SRX without AWD being built with the smaller footwell but I suppose it's possible.
    Anyway, good luck.
    MortnCyn's Avatar
    MortnCyn is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 N* Thunder Gray/Ebony AWD/NAV/MRC
    Mar 2004
    Illinois
    81
    875
    See attached 2003 article re the 2004 SRX AWD & traction control.
    jimb is offline Awaiting Email Confirmation
    Automobile(s): 2004 Cadillac SRX AWD, V-8
    Mar 2008
    South Carolina
    10
    I just looked under the front of mine when purchasing it and noted there were front axle shafts.....
    MortnCyn's Avatar
    Mar 2004
    Illinois
    81
    875
    Quote Originally Posted by jimb View Post
    With AWD and Carolina snow shoes (a.k.a. flip flops) you should have no problems this winter. Welcome aboard.
    laserguy's Avatar
    Dec 2007
    Canada
    45
    108
    Quote Originally Posted by MortnCyn View Post
    check RPO codes....
    http://www.cadillacforums.com/forums...-srx-05-a.html
    Laserguy
    Retep's Avatar
    Retep is offline Cadillac Owners Member
    Automobile(s): Cadillac SRX '04 AWD V8
    Aug 2008
    St-Sauveur, Quebec,Canada
    58
    57
    Interesting read.
    Thanks guys for posting this link for the RPO Code. Went right away to the car and searched for it. Since I bought it used I wasn't sure what I got in there.
    Found the label (thanks Northern SRX) took a picture and punched all those numbers in.
    Heck - for a few minutes I was worried that mine is not a AWD and the used car dealer where I bought it shafted me
    Turned out it is AWD
    Nov 2006
    Ottawa, Canada
    950
    Quote Originally Posted by Retep View Post
    Interesting read.
    Fantastic!
    This forum has been a great resource for me - only too glad to be able to pay it forward.
    robhersch is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 SRX N*V8 RWD; 1999 DeVille Concours
    Apr 2005
    Fullerton, CA
    513
    AWD should have 3 differentials: a differential at the transmission with a drive shaft to a front differential as well as a drive shaft to a rear differential.
    RWD has only one differential at the rear and only one drive shaft fron the trans to the differential.
    Look under the car! Good Luck!
  16. #14
    Nov 2006
    Ottawa, Canada
    950
    Interesting read.
    Do you have magnetic ride control? check for codes FE3 and F55. If so, it might explain why you fell in love with the handling...
  17. #15
    Autobahn_Burner is offline Cadillac Owners Fanatic
    Mar 2007
    Germany
    121
    Like Jimb said, the safest way remains looking if drive shafts are present on front hub...
  18. Remove Advertisements
