Cadillac SRX First Generation Forum - 2004 - 2009 Forum for discussions regarding the Sigma-based Cadillac SRX.
 | Cadillac Forums: strange humming noise coming from rear
06-18-08, 11:15 PM
| | Cadillac Owners Member | | | | | Re: strange humming noise coming from rear I have an 04 with 34000 miles, humming noise from the RR area, needed new wheel bearing assembly. |
06-19-08, 03:05 AM
| | Cadillac Owners Member Cadillac(s): Cadillac SRX | | Join Date: Dec 2007 Location: British Columbia | | | Re: strange humming noise coming from rear As noted earlier about a month ago the dealership replaced the torque converter in my '05 N*. Since then no problem and no noise. |
06-20-08, 12:24 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | Re: strange humming noise coming from rear Have 05 AWD SRX (4000 miles), Makes rear end whine like bad ring & pinion at 25 to 30 mph at light throttle and even more whine at 40 MPH under compression! Cadillac has replaced rear end, both rear wheel bearings. Still has same rear end whines. They are to look at car again next week. My info is this is common in AWD SRX's  |
07-27-08, 03:52 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | Re: strange humming noise coming from rear I have 07 srx,2wd. same humming intermittent noise, goes away when accelerating,otherwise it's always there, seems like a tire out of round, but there's no bumping which leads me to believe some thing to do w/ drive train. Dealer says every thing is fine. It' driving me nuts. Help!!
Duke. |
08-22-08, 01:01 AM
| | Cadillac Owners Member | | Join Date: Apr 2006 Location: Calgary. Canada | | Re: strange humming noise coming from rear '06, N*, AWD. Just came back from dealer after my second visit regarding an annoying hum coming from the rear end usually occuring at about 1500 rpm. Initally dealer claimed issue with exhaust note. However after the last visit they concluded the torque converter required replacement. Replaced. Happy at last ....
Don't let them tell you it is some other issue. GM has issued a bulletin to replace the converter. Don't take anything less. |
09-05-08, 01:15 AM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac SRX AWD/NAV | | Join Date: Dec 2007 Location: Canada Age: 37 | | | Re: strange humming noise coming from rear I paid 200$ to diagnostic this noice..whells hubs...
each hus is around 700 with labor...1500 pair...
Good luck
LaserGuy |
04-22-09, 11:29 AM
| | Cadillac Owners Member Cadillac(s): 04' SRX V8 | | Join Date: Feb 2009 Location: Charlotte, NC | | | Re: strange humming noise coming from rear Quote:
Originally Posted by am6948 I have an 04 with 34000 miles, humming noise from the RR area, needed new wheel bearing assembly. | How much does that run? Mine was making the humming noise now I get a slight squealing from the RR tire. I think it's a bearing also, but I'm out of the warranty. |
04-26-09, 10:35 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: strange humming noise coming from rear Quote:
Originally Posted by CadJack '06, N*, AWD. Just came back from dealer after my second visit regarding an annoying hum coming from the rear end usually occuring at about 1500 rpm. Initally dealer claimed issue with exhaust note. However after the last visit they concluded the torque converter required replacement. Replaced. Happy at last ....
Don't let them tell you it is some other issue. GM has issued a bulletin to replace the converter. Don't take anything less. | Cadjack- Do you know what bulletin it is that was issued for the torque convetor?
I have an 04 SRX that makes a humming noise anytime I'm on the highway,I cant hear the noise when the radio is on but If it's off I can tell its there. |
11-04-09, 02:21 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: strange humming noise coming from rear Anyone know what the Service Bulleting # is on the Torque Converter? I may have the same issue and it is driving me nuts...
Also, anyone know if the service bulletins are covered by GM? I am out of warranty on my 04 V8 and assume this is a pricey fix.
Thanks | | Cadillac Discussion Tools | | |
Censor is ON | | | |
