Results 1 to 12 of 12
    05awdupstater is offline Cadillac Owners Member Cadillac(s) I Drive: Cadillac
    Sep 2006
    57
    Normal rapping noise in engine
    The Caddy dealer has had my 05 V6 AWD SRX for two days. It has a loud rapping noise when starting cold. Lasts for 3 seconds or so. They confirmed the noise exists, but cannot figure out what is causing it. The dealer just called to tell me that I can pickup my car. It is not fixed. They need to setup an appointment with the area service rep from GM to "see if the rapping noise is normal or not". Exact words. Do any of you have this normal rapping noise?? Also, the dealer changed my oil about 3300 miles ago and it is black as night. They suggested I change it again to see if the noise goes away. Anyone else have the normal rapping noise and black oil after 3,000 miles or so? My 07 STS4 V6 does not rap and the oil is golden brown after 3,000 miles. What should I do next??
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    Many
    c5 rv's Avatar
    c5 rv is offline Cadillac Owners Connoisseur Cadillac(s) I Drive: 91 Allante (gone), 06 SRX (gone)
    Jun 2003
    Michigan
    4,271
    Re: Normal rapping noise in engine
    I ran my 04 CTS with the 3.6 engine for about 50K miles before trading and my current 06 SRX with the 3.6 engine has about 25K miles. Neither ever had/has rapping or cold start knock. I had a 99 Sierra and an 02 Avalanche, both with the vortec 5.3, and both with cold start knock for a few seconds on startup.
    srx2005 is offline Cadillac Owners Member Cadillac(s) I Drive: 2005 SRX V6 AWD; 2000 Eldorado ETC
    Feb 2007
    South Jersey
    82
    2005 AWD V6. Still have vehicle and have never heard a cold start rapping noise in 33.5K miles.
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads):
    The Tony Show's Avatar
    The Tony Show is offline Fake Man Body Quadrant Cadillac(s) I Drive: 04 CTS-V, 05 STS, 07 SRX- All sold :(
    Dec 2004
    The Internet
    19,744
    Blog Entries
    My '07 3.6L does it occasionally. Talked to my Service Tech and he told me it's the cam phasers, which sounds believable. The vehicle runs great and only makes 3 or 4 quick taps on startup, so I'm not worrying about it.
    Rest in Peace, J.D. (aka Dirt_Cheap_Fleetwood)
    King3244 is offline Cadillac Owners Fanatic Cadillac(s) I Drive: 2007 SRX
    Oct 2005
    347
    There is a tsb out on it. Google Cadillac tsb's for your particular year. I had an 04 N* that did it on cold starts when I got to 45,000 plus miles. I have the tsb at home.... unfortunately for you I am a snow bird and won't be back home for another 6 weeks. They fixed mine under warranty after I took in the tsb and showed it to them. They claimed that they couldn't find one when I told them about it. (aint the internet a wonderful thing)
    It has to do with the tensioners for the overhead cams and is a well know problem.
    I believe we also had a thread going on here....search cold start and see what you get.
    john d is offline Cadillac Owners Enthusiast
    Sep 2004
    GRANITE BAY, CA
    70
    861
    I hate rap too....change stations
    jmayhew is offline Cadillac Owners Member Cadillac(s) I Drive: Cadillac SRX
    Dec 2006
    Pittsburgh
    34
    37
    Quote Originally Posted by King3244 View Post
    can you post the link to the TSB.....my wifes SRX has the problem on cold startups...might bring up the issue when i take it in for the seal recall.
    RobVuk is offline Cadillac Owners Fanatic Cadillac(s) I Drive: 2008 SRX V8 AWD Sport
    Oct 2007
    Nashville, TN & Chicago
    196
    I have an 08 Northstar with 5,000 miles and it started making that noise on startup any time after a couple of hours of sitting. I took it in to the dealer. The cam phasers have been replaced to solve the problem. There is a pin that is supposed to drop to hold the cam timing until the oil pressure builds up in the hydraulically controlled phasers. It is NOT normal and if you have a warranty, I'd get it fixed.
    The 6 cylinder also has VVT so I would guess it's a similar problem.
    73Thumper is offline Cadillac Owners Fanatic Cadillac(s) I Drive: Cadillac
    Apr 2007
    166
    05awdupstater, geez, what kind of a dealer do you have? Just teasing, I had the same issue, my dealer also did not have a clue. As RobVuk stated - it was the cam phasors. (mine was/is a 2007) I brought it the TSB, but it did not help - they treated me like a idiot. They would need to consult with the area rep. and he told them - replace the phasors. Note - they wanted me to change the oil as well to see if it would help. (before they would call the area rep) I said I don't think so - you want it changed you pay for it as it only had about 1000 miles on it. The cam phasors are a known issue and tend to fail early vs late - mine only had 6000 miles on it. Also the description of the failure mechanism as RobVuk stated is right on the money.
    Make sure they have the parts IN STOCK before they start the repair. This is not a 1 hour job, make them give you a nice loaner as I doubt you will have it back the same day.... After the repair mine did not seem as good as it was as new - but now the "rap" is subdued, lasts only 2 seconds max, and only after the car sits for more than a day or 2. I amy just be critical though - it runs strong with no other issues.
    Sep 2006
    57
    Angry Re: Normal rapping noise in engine
    Thanks for the replies. In regards to the cam phasers on the N* vs V6 VVT, I think I'll wait for the offical GM response. The dealer has a real good long time B/S artist as the service director. We had a hour long chat a few days ago and his tone of voice kept changing upon my questioning him. He was either making things up as he went along or his offical GM undergarments were creeping up somewhere dark. I bought 2 different Caddy's from two different dealers in the past 2 years. The '05 was Caddy Certified. It wasn't even close to being retail ready. Drove 2hrs to get to dealer. Long story, bad experience. Second dealer a little better but car was not 100% right and the paperwork was all F'd up after I waited 2 hours. I did receive my NYS Title today on the '07 STS with no lien on my offical ownership document. More mistakes seemed to have happened. Anyhow, the servicing dealer did not have anything close to the model and equipment I wanted on either purchase, so I am suffering from bastarditis. Most likely these will be the only 2 Caddy's in my career. I have been treated much better at the Chevy dealers than the GM Corporate flagship. Oh well, I guess the next hurdle will be the rate of depreciation these beauties seem to experience come trade in time.
    Tommy Trojan is offline Cadillac Owners Member Cadillac(s) I Drive: 2008 SRX V6
    Apr 2004
    Chantilly, Virginia
    51
    33
    I'm guessing "piston slap" that I used to hear on my Olds van 3.4 V6 when cold or carbon buildup. After 30-60 seconds, the sound goes away - right? The piston slap was heard every morning, but the engine was still going strong when I traded the van in after 10 years. I learned to live with it.
    Oct 2007
    196
    Quote Originally Posted by Tommy Trojan View Post
    No. This only lasts 2 to 3 seconds until oil pressure pumps up. It's the cam phaser.
Simply register and/or login to remove these advertisements.
  • You may not post replies
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum | kia forte forum | used car savings
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
