Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac SRX Forums > Cadillac SRX First Generation Forum - 2004 - 2009
Cadillac SRX First Generation Forum - 2004 - 2009 Forum for discussions regarding the Sigma-based Cadillac SRX.
cadillac-srx
Cadillac Forums: Sirius done in 04 SRX NAV/RSE
Old 01-13-08, 01:32 AM
Cadillac(s): 04 SRX AWD V8
View conedoctor's Photo Album
Casino Cash: $9080
Very very easy to do, about 1-2 hours if you have your tools ready.
I did it all behind the dash, spliced the harness, mounted the SIR-GM1 and mounted the antenna under the dash.
Only 6 wires and no power tap, the power is in the factory harness.
Bed time now.
Matt
  #2 (permalink)
Old 01-13-08, 06:28 PM
Cadillac Owners Enthusiast
Cadillac(s): 02 Seville, 04 SRX
View Yaemish's Photo Album
Casino Cash: $2425
Re: Sirius done in 04 SRX NAV/RSE
How come behind the dash? Where did you mount eh SIR-GM1? I had to install it in the back and it was a pain in the ass because I had to take all the molding out.
  #3 (permalink)
Old 01-13-08, 06:29 PM
Cadillac(s): 04 Cadillac SRX N*
View BrownStarfish's Photo Album
Casino Cash: $410
Would you mind posting some detail please? I want to do the exact same thing. Just the wiring details would be great, I've already had the dash apart once. Thanks man.
  #4 (permalink)
Old 01-13-08, 06:45 PM
CadillacSTS2003's Avatar
Zeeee-yaaaa
Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC
View CadillacSTS2003's Photo Album
Casino Cash: $12230
probably just used the pin out and spliced into the radio or the lower disc change
i know Yaemish knows the pin out for th SIR-GM1 and it has been posted but do you guys want me to post the pin out of the SRX changer?
  #5 (permalink)
Old 01-13-08, 07:38 PM
Casino Cash: $9080
He speaks the truth, I will post it all later today when the kids are in bed. The SIR-GM1 fits to the right of the radio, the antenna between the vents under the dash and yes the CD harness splice was done.
Give me some time and I will post.
Thanks Matt
  #6 (permalink)
Old 01-13-08, 07:44 PM
Zeeee-yaaaa
Casino Cash: $12230
figured as much lol
i may finally install one in my STS with nav
  #7 (permalink)
Old 01-13-08, 10:50 PM
Casino Cash: $9080
In no way am I responsible for anything you do, this could be wrong and I could have made mistakes.
This is assuming you have RSE
The pin outs are from another post and the picture is from Yaemish (very helpful)
Tools needed
Soldering iron
Wire cutter/stripper
Sharp knife
SDAR interface harness from SIR-GM1
7mm, 10mm socket
Phillips screwdriver (short one or 90 degree)
Print out of stuff below
Pull out your center vents, I had to pull real hard and use a screwdriver to get it started in the sides. Flip it up on to the dash
Pull out ashtray insert, undo 7mm bolt about 5cm in the hole you see.
Pull out HVAC controls, same as vents pull hard. Let it hang into the drivers foot well.
Undo 4 10mm bolts, put a pad on the shifter to rest the radio on while you unplug everything then set the radio aside.
Find the white 16 pin harness the was plugged into he passenger side of the radio, make two cuts with the striper on each of the following wires then cut off the cover with the knife.
Cut the white connector off the SIR-GM1 harness, cut back some of the cover and you will see the grounds spliced together cut one off.
Now all you have to do is match the picture with the harness pin outs, I am colour blind so I use position not colour.
Wrap the wire around, solder and tape.
Now pull the glove box liner out a bit so you can get your hand in above, pop the SIR-GM1 in harness side up and get it in the area beside the radio.
Put the antenna on top of the vents in the middle, stuff it in far so it is wedged into the padding a bit. Put all but about 24" or so of the wire under the vents, run the rest down to the SIR-GM1 and plug it in.
Plug in the harness you spliced.
Plug in the radio and test, you should get CH 184 if you do your good put it together.
Write down the ESN and activate, you have to have it on so make sure you are ready or do a delayed activation online.
Connector Part Information
7123-7169
16-Way F Yazaki (WH)
Pin SIR-GM1 harness
Wire Color
Circuit No.
Function
1
BK/WH Thick black
851
Ground
5
BN/WH White
368
Remote Radio Right Audio Signal (U2K/U2L/U42)
7
PU Purple (I think)
1807
Class 2 Serial Data (Primary)
13 Thin Black
D-GN/WH
372
Remote Radio Audio Output (-) (U2K/U2L/U42)
14 Reddish (I think, I can't see the colour)
TN/WH
367
Remote Radio Left Audio Signal (U2K/U2L/U42)
15 Purple (I think)
PU
1807
16
RD/WH Yellow or Red maybe
2240
Battery Positive Voltage
  #8 (permalink)
Old 01-14-08, 02:31 AM
ucyiwork's Avatar
Cadillac(s): Cadillac
View ucyiwork's Photo Album
Casino Cash: $1350
If this is done behind the radio, why is the rse needed here? I am planning on knocking this project out this weekend or rather attempting it. !hat do I need to do differently if I have bose, nav, and no rse please. conedoctor and yameish are the best.
  #9 (permalink)
Old 01-14-08, 10:52 AM
Casino Cash: $410
Thanks for putting this together conedoctor. How's your signal been, dropouts? Did you test the antenna in that location using a radio with a signal indicator? Did you see full strength?
  #10 (permalink)
Old 01-14-08, 11:47 AM
Casino Cash: $9080
If you don't have RSE I would think the 3 digital audio wires are not there, you would need to add the left, right and common then get your dealer to tell your radio you have digital audio. You should be able to just add pins to the factory plug, not sure on the part# for the pins.
The class II and power should be there for the CD player.
I have not had any drop out so far but I don't think I will have any problems, I have it set up almost the same way in my Sierra and I have had ZERO reception problems in over a year. I was also in the garage when I hooked it up and it was still fine, I just don't want some stupid wire and antenna on the roof of my car.
  #11 (permalink)
Old 01-18-08, 05:32 PM
Casino Cash: $2425
I like this better than the way I did it; pulling out all the molding in the back seems a lot harder. It should also be mentioned that nothing needs to be done in terms of programming your radio. My SRX did not come with the XM option and when I connected the power to the SIR-GM1, the radio picked it up immediately.
It should be noted that the radio shows as XM1 and XM2 and there is no way to change that. But one the bright side, the seek controls on the steering wheel work with the unit (they didn't work with my Seville install; though I think I can fix it).
  #12 (permalink)
Old 01-18-08, 11:29 PM
Casino Cash: $410
Color blind or not, Conedoctor was spot on with the wiring info. Thanks again. I completed my installation last night without any major hassles. XM1/2 was there as soon as I turned on the power.
Two (very minor) complaints I have: 1. Only a 16 character display when Sirius gives 32. 2. Presets show P1-P6 instead of the Sirius Channel #, it would be really cool if it would show the artist/song in that spot... Anyway, the better sound quality and having the steering wheel controls blow my previous, external, FM transmitter solution away.
  #13 (permalink)
Old 01-19-08, 07:00 PM
Casino Cash: $9080
Drove around all day in the snow with heavy cloud cover and snowing and all my windows are tinted, no sigal problems at all.
Put the antenna under the dash I say.
  #14 (permalink)
Old 01-20-08, 08:02 PM
Casino Cash: $2425
I installed a Sirius radio for someone a few weeks ago and the antenna that came with the kit seems to pick up the stations a little better than the one that came with the SIR-GM1 kit. Its the round antenna as opposed to the small ssquare one (its kind of ugly though). When I say it works better, it doesn't always drop when driving under a bridge.
  #15 (permalink)
Old 01-20-08, 08:18 PM
Casino Cash: $9080
Mine never drops out under a bridge, I did lose it in a tunnel but only after like 5-10 seconds as I think the SIR-GM1 has a buffer in it.
Tags: , , ,
nav or rse, sirius, srx
