Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac SRX Forums > Cadillac SRX First Generation Forum - 2004 - 2009
Cadillac SRX First Generation Forum - 2004 - 2009 Forum for discussions regarding the Sigma-based Cadillac SRX.
cadillac-srx
Cadillac Forums: Turn signal bulb burned out
  #16 (permalink)
Old 02-20-08, 12:09 PM
ewill3rd's Avatar
Cadillac Technician
Cadillac(s): none
View ewill3rd's Photo Album
Casino Cash: $16917
Re: Turn signal bulb burned out
It is actually not a published bulletin yet, but they should be able to find it in Service Information.
The socket should always be inspected, they actually fail more than the bulbs do.
Here is some info.
Subject: Turn Signal bulb and socket - Replacement Parts
Models: 2004- 2007 Cadillac SRX
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may comment the turn signals flash faster than normal or are inoperative. In that event, bulb replacement or socket replacment is available rather than replacing the complete lamp assembly.
Recommendation/Instructions:
Inspect the Turn Signal Bulb Sockets. If the bulb contacts appear to be overheating, replace the bulb socket. It is not necessary to replace the complete lamp assembly. The lens for the Fog Lamp needs to be removed from the lamp. There are several fasteners that hold the two pieces together. Once the lamp is opened, you will notice that the socket for the turn signal has its own connector. Disconnect the connector and install the new socket. The part number for the socket is 19120947 and can be found in group 2.596. The part number for the turn signal bulb is 15862271. Do not use any other bulbs.
Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group.
  #17 (permalink)
Old 02-20-08, 12:10 PM
ewill3rd's Avatar
Cadillac Technician
Cadillac(s): none
Casino Cash: $16917
We used to replace the entire lamp assembly before they gave us a service socket.
No need to remove the bumper, it is not easier by any stretch of the imagination.
In fact the easiest way is to remove the inner fender, then take out the 6 torx screws that hold the lamp assembly together and leave the lens in the bumper.
You can open the lamp and access the socket easily that way. Replacement is easy.
This should always be checked if a bulb is not working.
  #18 (permalink)
Old 11-15-08, 06:06 PM
Cadillac(s): 06 SRX
View ktr-sb's Photo Album
Casino Cash: $560
Dude, hands down, this has got to be the easiest way. I haven't tried the remove-the-front-bumper-cover method, but I have tried the do-it-by-removing-the-air-filter-box, and removing the fender liners was easiest. Took me about an hour and a half for both sides, and I was taking pix. Check them out at http://srxturnsignals.shutterfly.com
  #19 (permalink)
Old 11-15-08, 06:13 PM
ewill3rd's Avatar
Cadillac Technician
Cadillac(s): none
Casino Cash: $16917
Nicely done, thanks for the pics, that is the easiest way I have found to do that job.
  #20 (permalink)
Old 11-16-08, 08:39 AM
GMJim's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 1980 Coupe Deville, 1990 Eldorado, 2006 SRX
View GMJim's Photo Album
Casino Cash: $11687
Smile Re: Turn signal bulb burned out
ktr-sb, Great Job. Thanks.
Tags: , , ,
bulb, burned, signal, turn
