Group 101 Battery Alternatives
Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 15 of 73
Like Tree4Likes
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Group 101 Battery Alternatives in Cadillac SRX / XT5 Forums; I have never been a fan of Delco batteries. They're OK . . . but. Here is part of a ...
    Rod04 is offline Cadillac Owners Member
    Feb 2006
    So Calif
    48
    Here is part of a post from Heavymetals of about a year and a half ago
    from the CTS forum:
    The battery is a 690 cca ACDelco in a fairly new group size: 101. Not many places carry a group 101 battery, and those I found were pretty pricey. Now, it turns out that a group 101 is almost exactly the same width and length as a group 78 battery, and about a half-inch shorter. In the cts, incidentally, it sits on a battery tray that's at least that thick.
    Solution: Wal-Mart MAXX group 78N. 900 cca. Warranted free replacement for 3 years, prorated replacement for years 4-9. Top of the group 78 ratings at Consumer Reports, and a best buy. Paid all of $68 + tax.
    It's a tighter fit than the original, but not so tight as to require bending, cutting or hammering. I though I might have to 'adjust' the thickness of the battery tray, but doing so was not required.
    Yesterday I was at a Walmart and got measurements for three of their batteries.
    Model/Group CCA L inchs W H
    MAAX 34/78S 700 10 15/16 6 7/8 7 1/4 Side + Top Posts
    MAXX 34S 660 10 15/16 6 7/8 7 13/16 Top Posts
    MAAX 78S 650 10 15/16 7 1/4 7 1/4 Side Terminals
    Price for 34S was $68.48 and 78S was 62.28
    I saw no mention for "78N." And of course, our local WalMart store being essentially self-service, there was no one whom I could ask. All MAAX products were clearly labeled as "distributed by Johnson Controls." Dimensional info above was from a booklet entitled "Everstart Application Guide.
    CCA ratings on these batteries were lower than for the 78N mentioned by Heavymetal. Note "N" vs "S" in the model designation. Not sure reason. Perhaps Johnson has made some redesign or the rating method has changed in the interim. Perhaps the battery of two years ago was to capable vs the competition so Johnson pulled some plate surface out of the design.
    Anyone know the dimensions for the Delco 101? Any other info or thoughts?
    jpettit's Avatar
    jpettit is offline Cadillac Owners Member
    Automobile(s): 2007 Cadillac SRX V-6 RWD
    Oct 2007
    78
    Re: Group 101 Battery Alternatives
    The new 2008 SRX has a different battery altogether. It is now a standard recessed TOP POST battery rather than GM's typical side post battery. The terminals have also been reversed; the positive terminal is now on the driver's side and the battery cables on older models are long enough to reach. A dealer could tell you what group number is being used.
    My Wal-Mart carries the 78S, but no 78N or 101.
    PS:The SRX also has unique fuses that are shorter than the mini. Not in stock at auto supply stores or specialty fuse companies such as Fuseco. Good luck.
    MortnCyn's Avatar
    MortnCyn is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 N* Thunder Gray/Ebony AWD/NAV/MRC
    Mar 2004
    Illinois
    81
    875
    My collection of fuses were certainly too large. Found out about the mini-mini fuses after buying some Littlefuse mini fuses. The fuse puller was still too large to pull the SRX fuse. Realized there is a fuse puller on the fuse box and pulled the 20-amp fuse in question to find out it is really mini.
    Feb 2006
    So Calif
    48
    Would still love to know if anyone has the measurements of the OEM Gp 101 battery.
    Also good info to know that the fuses in the car are of proprietary size. Better to find out this way than at 2am on the road. Will get a few to put into glove box 'just in case.'
    Feb 2006
    So Calif
    48
    Finally had some free time and got the WalMart MAAX 78s battery for my 2004 6 cyl SRX. It fits fine.
    Only tiny issue was that the WalMart (Johnson Controls) battery has a plastic carry handle that slides down to top of battery when not in use. There was a tiny bit of interference between this handle and the plastic battery cover (Cadillac factory installed) that goes over the battery after the battery is installed. I think the handle retained a tiny bit of curvature after I used it to pick up the battery. End result was that I was not able to fully engage and lock the two tabs (located on the driver's side of the battery) on the cover into the female slots. Nevertheless, the cover is there for cosmetic reasons only and isn't going anywhere anyway since it is retained on the top by the cowling (or whatever it is called) and associated outside air intake plenum that sits immediatley above the battery and below the bottom of the windshield. The battery connections also penetrate the cover on the front of the battery and the cables and connectors also hold the the cover in place.
    If you choose to change your battery yourself, make sure you have lots of metric wrenches including a short 7mm socket and ratchet wrench to remove the hex head screws that hold the side of the air plenum and cowling on the side of the engine compartment where the battery sits. And also make sure you have an inch based wrench to remove the battery's cable connections.
    The battery fits very snugly in its hole. Changing it isn't like changing the battery on your '57 Chevy. Also, the battery may stick to the bottom of the battery support and you may have to pry carefully to break the bond between the bottom of the battery and its support. You will not be able to move the battery in the slightest until you have broken this bond.
    jpettit's Avatar
    Oct 2007
    78
    Try this other thread for more information and dimensions. See:
    http://www.cadillacforums.com/forums...m/t-70653.html
    Feb 2006
    So Calif
    48
    Thanks for link. Enjoyed reading the thread.
    The posters are right about the battery. It is a bit anemic looking and on the small side. So is the hole into which it just barely fits. Must be both a cost cutting and weight cutting move so that the fleet average for gas mileage improves a bit. Thank the good Lord I live in a temperate part of So Calif (hasn't snowed around where I live since the 1930s). Plus, the engine is the V6 which should require a little less current to crank than the V8.
    Having the dash mounted CD changer cycle CDs all night for several nights didn't help the battery one bit. Dealer changed out the CD changer on warranty, but I didn't ask for a new battery and they didn't offer.
    BTW, my dealer charges about $235 to put in a new Delco Gp 101. My 10 year old son and I did it using the WalMart/Johnson Controls MAXX 78S for $68.28 plus tax and I trust he learned something.
    DP Dave is offline Cadillac Owners Member
    Nov 2005
    OC
    5
    SRX Battery Replacement 2005 V6
    After reading some threads I see where non-Delco batteries have been purchased that fit. IE - Auto Zone, Wal-mart, etc.
    HOWEVER I do not see the codes for the batteries - can someone help with the numbers so when I go to the store I can request a SPECIFIC battery? If I say it is for a 2005 SRX they will say that they don't carry a battery for the SRX.
    Thanks for your help!
    King3244 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 SRX
    Oct 2005
    347
    Re: SRX Battery Replacement 2005 V6
    Why not just go with the dimensions and amp rating and get a battery that fits within the parameters??
    Nov 2005
    OC
    5
    Quote Originally Posted by King3244 View Post
    I went into the following retailers websites and none of them listed a battery for the SRX: Sears, Kragen, Auto Zone. I called Costco and they don't carry one that will fit so I took a Forum Members advice and I took the battery to Auto Zone and was able to get a match (almost - just a bit taller) #160592 78-DL 7 Year/84 Month with a free 24 Months Free Replacement $79.99
    I did have to trim off a about 1/4" from the bottom of the trim which sits above the battery (not visible unless you stick you head under and look back up). Was easy to do with some tin snips.
    Larry05 is offline Cadillac Owners Fanatic
    Automobile(s): SRX
    Feb 2005
    142
    Quote Originally Posted by DP Dave View Post
    This is what you want to do to replace a battery. GM could have spec'd a more standard battery. But no. Hello bankruptcy.
    GMJim's Avatar
    GMJim is offline Cadillac Owners Connoisseur
    Automobile(s): 04,06,10 SRX; 2011/14 CTS Wagon
    Oct 2005
    GM Product Development
    1,803
    Larry, You are not a Cadillac owner/enthusiast any more. It's time for you to move on to
    http://us.lexusownersclub.com/forums/, and leave this forum to those who support
    America.
    Oct 2005
    347
    Yes....scoot along now!
  16. #14
    Automobile(s): SRX
    Feb 2005
    142
    Quote Originally Posted by GMJim View Post
    America.
    Hecho en Mexico.
  17. #15
    Automobile(s): SRX
    Feb 2005
    142
    Nah, its too much fun pulling all of your chains.
    Love to read about all the problems with the SRX.
  18. Remove Advertisements
