Rear wiper sprayer? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Rear wiper sprayer? in Cadillac SRX / XT5 Forums; Yes, but the pump contacts may be bad....
  1. #16
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,879
    Re: Rear wiper sprayer?
    Been fixin' cars for 74 years
  2. #17
    orandaberg Guest
    Thanks did not think of the plug being bad If no contact at plug, I will go higher up the wire with the test lamp. After shipping and taxes that switch would cost me well over a 100 bucks, was happy to bench test the pump and found it to work, that was the same price, bad plug may just need cleaning
    Thanks
  3. #18
    Jschuch is offline Cadillac Owners Member
    Jul 2004
    13
    I had same symptoms. Traced the whole line. Turned out to be a crusty nozzle. Earlier post is right on. Flip the pivot cover. Pull straight out very carefully. Clean out with a pin, press in, and aim with pin to spray om window. Nozzle is prone to plugging.
  5. #19
    orandaberg Guest
    Now the manual shows this as the rear washer pump
    This as the windshield
    If thats the case I have been backwards on this the entire time! I am not at home now to verify but in a week or so I will verify the line up and if thats the case then I tested the wrong motor! But this means pulling the entire bottle out again. PITA! It could be one of the pumps does not work and for a quick fix they just swapped over connections since both are the same
  6. Remove Advertisements
