Service Tire Monitor
Results 1 to 7 of 7
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Service Tire Monitor in Cadillac SRX / XT5 Forums; I've driven the car for 189 miles and I get my first issue (aside from the tailpipes) I have to ...
    snaayk is offline Cadillac Owners Member
    Apr 2004
    71
    I've driven the car for 189 miles and I get my first issue (aside from the tailpipes) I have to service my tire monitor system. I no longer get read outs on tire pressure. I think it's probably because I had my wheels changed out for 18" at the dealer, since it wasn't a factory option. They probably screwed something up...I'm taking it in next Monday..let you all know.
    gman89 is offline Cadillac Owners Fanatic
    Jan 2004
    213
    Re: Service Tire Monitor
    I got a Service Tire Monitor on my SRX today. The left front monitor is not showing a pressure. How does this system work?
    JODAOR is offline Cadillac Owners Member
    Dec 2003
    12
    The system operates using RF signals sent from the valve stem assemblies. Each wheel has this sensor attached to the valve stem itself and is powered by a very small battery that is encased within the assembly. In the fenders arches of the vehicle, there are receivers that send signals to the central compuer of the truck. Keep in mind that the system monitors tire pressure through a small pinhole in this valve stem. If your wheels were changed out, they did not take the valve stems from your factory wheels and instal them in your new ones. They will fit as long as you are using one piece wheels.
    Hope this helps.
    Apr 2004
    71
    They had to order a part, $900, and it's now working....
    rusgmil is offline Cadillac Owners Member
    Dec 2003
    NW Indiana
    13
    What is the service life of the battery thats encased in the stem? Doesn't sound like its replaceable.
    globie is offline Cadillac Owners Member
    Mar 2004
    7
    1500 miles on my beautiful SRX, and I just got a message on my display screeen "Service Tire Monitor." Is this the same issue that you're talking about here?
    Apr 2004
    71
    yeppers...
  10. Remove Advertisements
