I have an entire motor I am parting out. It is a 3.6L V6 out of a 2005 Cadillac SRX. The right side timing chain jumped off and resulted in getting a new motor. There are a ton of good parts left over
The motor had only 55k on it and had maintenance done regularly.
Intake plenum with sensor and black box $100
Left and right manifolds $50 each
Fuel rail with 6 injectors still mounted $100
Wiring harness $100
Oil pan $50
6 coil packs $10 each or $50 for all
Valve covers $30 for left side $15 for right side. Right side has crack from timing chain but can be epoxied.
The motor has almost all of the sensors still on it. Call or text for specifics.
I have not yet tore the heads off but will be. I know the left head is 100% good the right head looks to be ok. I will have two pistons for sale, heads, cams, etc in a week or so. Call for any specific parts you may be interested in.
The block will be a coffee table in around a month that will be for sale as well!
Call or text anytime for information
404-583-2889
Thanks,
Justin
