  Follow CadillacOwners on Twitter
Cadillac Forums: Sweet Deal On 96 Eldorado
Old 02-25-07, 03:40 PM
Cadillac(s): 96' Eldorado, 00' Volvo 770 N14+ 525HP
View 9BlackN*Black6's Photo Album
Casino Cash: $360
Talking Sweet Deal On 96 Eldorado
Hello everyone,
Im new to the forum, so heres goes chapter one of my new caddy!
I was getting get a new car and really wanted and eldorado becuase my moms is a 92 eldo with 290k and runs perfect. Found a couple on the internet after about a month of searching, and decided after crunching the numbers that $4500 is about what im gonna spend. So went to the bank with my mom, waiting to turn into the bank and BAMB!!!! We had just been rearended!
Young highschool girl ran into us doin like 40mph. Every one was ok, except other girls car(whole front end totaled) my moms back was a little sore but she got checked out at doctors and all is good. After seeing the damage to her car, I HAD TO GET AN ELDO! Her bumper was a little pushed in and exhaust tip was a little smashed, thats it!
Whatta safe car!
So, get $4000 from the bank the next week after accident and go shoppin!
Found one in a perfect rich, yuppy chicago suberb, Schaumburg, IL. It was at a dealer for 3500 so i figured 3985 out the door for tax title and fees.
Only scary thing was the car had high mileage, 144k, but i figured coming from a wealthy neighborhood the ex owner probably always took it in.
So after driving the car and inspecting I found the following:
Looks like a oil pan gasket leak
Service Ride Control
ABS and traction lights on
Check Emissions
A/C inop
Pass. Window will only roll UP with drivers switch, probably needs switch
pass. door exterior bottom molding missing
Right rear chrome bumper trim peice busted
12 disc cd changer missing magazine
All minor problems i figure i can fix. Walked away with the car for 3200 out the door and 800 in my pocket for repairs. On the way home the car felt a little sluggish compared to my moms 4.9L, so i figure it needed a tune up, probably why service emissions pops up.
So I wake up all cheery the next morning being a new cadillac owner
It wouldnt start!! Now the fun begins!
Replace plugs and wires, they were original, noticed it has a new coil pack (Just one) and needs the fuel rail recall. Ran alot better but still was hard starting, so now i move to the batt. Seen a power wire like 4 awg. , checked in the trunk its got all wires for a sub system in trunk already ran, good but bad! Bad because when they removed the power wire from battery to try and hide it, they stripped out poss. terminal on battery (Damn side post batteries!) So i pulled it out and got another bolt to get a bite. Then i load tested it, and it didnt drop below 10v and its pretty cold here. so i put it back in, and started my research, Thats how I found you guys!
Checked all my fuses and relays all are good.
Checked FPR while is was running, but no RPM change when i pulled it, it has vaccum from hose and no fuel dripping out of fpr. Hooked up my fuel pressure tester after it sat for week, got 0 psi, flipped key on/off several times to prime it, only had 7 psi, so i cranked it over several time and got it running.
Only getting 25psi idling and when i rev it up, im surprised its running! So I spent a week researching fuel pump prices, what a range of prices! Dealer wants $480 for an AC Delco, was very tempted due to a lifetime warranty it had but nahhh, didnt want a cheap offbrand pump made in china named master from autozone for $240, so i kept hunting. Found one at Pep Boys for 240, its a Carter pump made by Federal Mongul, USA! with a year warr.
Checked for 12v and pump harness. Replaced the fuel pump, was pretty easy, hardest part was getting the damn filler neck off and back on, also helps when you run it to empty with only bout 2 gal in the tank. Changed the fuel filter and put a little lucas in the tank. Fire right up! Whahoooo!!!
Went out this morning with my fingers crossed, fired right up! :low:
Ive read on here you can make your coolant temp show up on DIC by changing the ICP settings, Anyone recall this page?
Thanks for all the help you guys have given! BTW Ill post up some pics when get a chance.
Thanks,
Greg
  #2 (permalink)
Old 02-25-07, 04:05 PM
Casino Cash: $360
Hello everyone,
Im new to the forum, just got a 96 Eldorado. Has 144k on it and a few minor problems. Dealer wanted $3985 out the door, i walked away with it for $3200 out the door! Next day it wouldnt start, changed original plugs and wires, notices a new coil pack on it. Still didnt start right, check battery and found the poss. battery term stripped out, so i load tested batt. and put another bolt in it, still started hard. checked fuel press. regulator, no fuel dripping and it has good pull of vaccum from line. I drive a truck so i left the car sit for a week. got home checked fuel pressure and got 0 psi, got it running and was only putting out 25 psi steady even off idle. Got a Carter fuel pump made by Federal Mongul for $240. Installed pump, new filter and she fired right up!
Went out this morning crossing fingers, fired right up!
Thanks for all the helpfull info everyone!
Anyone recall how to get coolant temp to display on DIC?
BTW ill post some pics next weekend.
Greg
  #3 (permalink)
Old 02-25-07, 04:14 PM
CadillacSTS2003's Avatar
Zeeee-yaaaa
Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC
View CadillacSTS2003's Photo Album
Casino Cash: $12230
Re: Sweet Deal On 96 Eldorado
sticky in tech tips...
  #4 (permalink)
Old 02-25-07, 04:25 PM
AlBundy's Avatar
Cadillac(s): 1996 Eldorado Sport Coupe
View AlBundy's Photo Album
Casino Cash: $226735
You beat me to it ETC. I did it to my 96 Eldo. You'll love it.
  #5 (permalink)
Old 02-25-07, 04:30 PM
Zeeee-yaaaa
Casino Cash: $12230
ya and who posted it?
who?
yea thats right ME!
  #6 (permalink)
Old 02-25-07, 05:10 PM
Casino Cash: $360
I found the post for adding Coolant temp, worked lika charm, thanks for following up with all the options info, Cadillac1997ETC.
I noticed a aftermarket alarm on my car, but got no remotes when i bought it, under the hood theres a button to sense when hood is opened and a wire from that go to a wrapped wire loom with another wire comming out of loom to a add-on siren.
Also found a very small switch under driver side dash, around kickpanel. It was labeled on/off.
Is there a module or something under panel where switch is at that could possibly override factory alarm or would i be able to do that throught the DIC and heater controls? I want to remove aftermarket alarm and go with the factory alarm.
Thanks again!
  #7 (permalink)
Old 02-25-07, 05:19 PM
Casino Cash: $360
Forgot to say, wow what a power difference with new fuel pump than the old one. Also helps when your putting out more that just 25 psi, now i just gotta get fuel rail recall done, would you suggest getting a new fpr and having dealer install it when they do recall? The old one doesnt leak when vac. line pulled.
  #8 (permalink)
Old 02-25-07, 05:51 PM
View Ranger's Photo Album
Casino Cash: $27171
Check the Tech Tips section. I think it may be posted there.
  #9 (permalink)
Old 02-25-07, 06:11 PM
Casino Cash: $27171
The switch was probably installed by the previous owner.
If the FPR isn't broke, don't fix it. Easy enough to change when and if it goes.
Tags:
deal, eldorado, sweet
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
