Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
    mtflight's Avatar
    mtflight is offline Cadillac Owners Connoisseur Cadillac(s) I Drive: 2003 White Diamond DHS
    Jan 2005
    Dallas, TX
    2,104
    Unhappy bled brakes... now "Traction Engaged" and Serv. Stability message... hot wheels...
    Ok so I thought I'd baby the car, and bleed the brake lines... purge the old fluid out and put new one in..
    I ordered some self-bleeding screws with built-in check valves (they work great to bleed brakes by yourself), replaced them in all 4 corners this weekend. I then bled the brakes and they work better.
    There was some dark stuff toward the bottom of the master cylinder.
    I think while bleeding them, debris may have gotten caught.... because....
    About 3 hrs after this, the "Service Stability System" message came on along with the brake (!) symbol.
    I checked the codes and it was TCS C1226 "Right Front Wheel Speed discrepancy" I turned off the car and reset the code.
    car was fine after that.
    day later, as I'm coming out of a stop, I feel weird action on the accelerator pedal.... like something spinning/bumping... then it's fine.
    Day later as the light turned green, I felt and hard pop / click coming off the line and the "Service Stability System" and brake light (!) were on again. I turned the car off and on and it went away. Code C1226 again.
    So I took the front wheels off to bleed the brakes some more today after work (get more fluid out and hopefully debris dislodged?) and found the wheels were quite hot. yeah I was using the brakes a little hard hoping the message would pop on again... but I dont' remember my wheels getting so hot.
    I then noticed both front wheel pads were stuck to the rotor. Is that normal with the car off? It doesn't feel like the car is braking when I coast. but I bet they "could" be touching lightly. I bet one of them gets stuck, and sets off the traction control message at best, and at worst the "service stability system" because one wheel speed sensor is detecting there is a difference in speed on the right wheel (it thinks there's a fault with the right front speed sensor, but I think it's registering properly.. and one caliper is sticking.. which one though).
    so I bled some more fluid out.
    I went for a drive and again coming out of a stoplight, I felt the weird vibrations on the accel pedal and looked down expecting to see the "service stability message, etc" and instead found "TRACTION ENGAGED" which I bet was the same message i would've seen two days earlier had I looked down.
    So... what do I do?! please help. I have an extended warranty that covers calipers and brake lines... is this the big opportunity to have the brake system replaced????? Or is this a common thing, sticky calipers?
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    Advertising world
    Many
    iametarq's Avatar
    iametarq is offline Cadillac Owners Connoisseur Cadillac(s) I Drive: 1998 SLS - 170,000 mi 05/2010
    Dec 2004
    Petoskey, MI
    29
    2,751
    Re: bled brakes... now "Traction Engaged" and Serv. Stability message... hot wheels...
    I've only bed a system once using the speed bleeders that allow for the 1 person bleeding team.
    when you were pumping out the old brake fluid did you do one corner at a time? Did you allow the brake fluid to empty out of the reservoir before filling it back up? Hopefully you kept topping it off before it allowed any air into the brake lines.
    I'm sure others will have more insight!
    mtflight's Avatar
    Jan 2005
    Dallas, TX
    2,104
    Thank you TarQ. I bled one corner at a time and kept topping it off. I should point out that I don't get the error/warning messages all the time.
    I will put the whole car on jackstands, and will bleed one at a time again hopefully tonite, this time until the fluid comes out clear hoping to dislodge anything that may be causing a caliper to stick.
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads):
    Ranger is online now Cadillac Owners Member Cadillac(s) I Drive: White Diamond '03 DHS
    62
    39,446
    Check the slide pins. If they are dried out and in need of lube, that may be causing the calipers to stick and not release. Also check the RF wheel speed sensor plug. Possibly the sensor is going bad but the timing is very suspicious.
    mtflight's Avatar
    Jan 2005
    Dallas, TX
    2,104
    I've never done brakes. What kind of grease does that require? Would this be something I find in the Chilton book (I do have that in addition to the FSM)?
    I assume this is easy to do.
    Regarding the wheel position sensor, it's built in to the hub. It's a magnet that registers every time it goes around so it can't really break per say. The replacement is the whole hub (speed sensors are a warrantied components so I may be able to get new hubs under warranty--I wouldn't mind that :-) ) One deductible.
    The error description says it's actually picking up a different speed than the others... so this may be the one sticking, if all the other wheels have speed sensors (rears too). If it's only the front wheels, well then either of the two calipers could be getting stuck.
    Gearheaad43's Avatar
    Gearheaad43 is offline Cadillac Owners Enthusiast Cadillac(s) I Drive: 1997 Polo Green Cadillac Seville STS
    Nov 2006
    Georgia
    687
    You need white litunum Grease for the sliders. The sliders are the screws that hold the calipers on the brackets, or a part of the assembly. You have to take out the sliders and lightly apply a fresh coat of Litunum grease on each one... Would not hurt to look at the brake pads, and you'll notice areas on the pads that "SLIDE" while in the calipers.... Grease those too...
    Just BE SURE you have NO air at all in the brake system!!! The rears can take a long time to bleed.
    It could be possible that the one-man brake bleeders you are using are not sealing properly, thus causing air to leak back into the system.
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Connoisseur Cadillac(s) I Drive: 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    3,726
    I've done floating caliper sliders before. You need High Temperature grease. White Lithium is not. The parts stores keep small packets of hi-temp brake grease. Tell them you need it for the caliper pins and they should point you to it. If you buy a pin/boot kit the grease comes with it. You won't need one unless yours are rusted.
    Patrick7997's Avatar
    Patrick7997 is offline Cadillac Owners Enthusiast Cadillac(s) I Drive: 2001 ESC, 2004 Escalade, 2007 HD Road King Classic
    Oct 2005
    Pewaukee, Wisconsin
    46
    699
    The grease you need for the sliders is hi temp silicone grease.... not white lithium grease.
    NAPA has soemthing called "Syl-Glide"... that's what you want...
    Or some other store equivalent....
    The wrong stuff will cause a lot of problems, though, so make sure it's right...
    iametarq's Avatar
    Dec 2004
    Petoskey, MI
    29
    2,751
    Quote Originally Posted by EcSTSatic View Post
    Good to know...when I did my rear brakes last fall I noticed that some parts of the pin were a bit rusty but I rubbed it off. I don't have any problems at the moment with the brakes.
    62
    39,446
    DO NOT use white lithium grease. I think brake grease mentioned above is a high temp silicone grease.
    There are sensors on all 4 wheels and they can break. I had that happen on my '92 which lit the ABS light. 6 months later the bearing started to howl. When I replaced the hub & bearing, the ABS light went out.
    If the slides are dry, you have to remove the rubber boot. Just pry it out of the groove with a small screwdriver. If the pins are rusted, you'll have to put them on a wire wheel to clean them up or replace them. After you re grease them, be sure to get the rubber boot seated in the groove so it seals out the moisture.
    mtflight's Avatar
    Jan 2005
    Dallas, TX
    2,104
    fellas thank you for the wise words. I'll start doing this when I get off work. Car brakes so much better now so I'm hoping it's as simple as greasing the deal.
    I haven't had the traction message since yesterday.
    EDIT: I forgot to mention that there's a certain smell that resembles burnt oil, but not quite. Could it be burning brake pads?
    Last edited by mtflight; 02-22-07 at 04:14 PM. Reason: burning smell from brakes possibly.
    62
    39,446
    Yeah, could be. This sounding more and more like a caliper hanging up. If so, it will be apparent when and if you see a brake pad worn excessively.
    97STS4ME is offline Cadillac Owners Fanatic Cadillac(s) I Drive: 1997 Seville STS, Black
    Aug 2005
    Charlottesville, VA
    144
    Dont forget that the traction control system uses the brakes to help restore traction. If you have a wheel speed sensor code, the traction control could be applying the brakes in an attempt to slow down that wheel. Check the contacts on the sensor to be sure there is no corrosion. Another possibility would be that you got brake fluid all over the sensor when you bled that caliper. (hopefully you used a hose that lead to an empty bottle or can to catch the fluid rather than just let it dump out straight into a drain pan) Brake fluid can conduct enough electricity to short a sensor, so make sure its clean.
  16. #14
    iametarq's Avatar
    Dec 2004
    Petoskey, MI
    29
    2,751
    Well, this spring I will definitely remove the calipers and inspect the pins again.
  17. #15
    mtflight's Avatar
    Jan 2005
    Dallas, TX
    2,104
    Could you take pictures please? I've never done brakes. I'm learning as I go and when I got home it was dark. I purchased the lube and brake cleaner, but after taking the wheels off I decided I had too little visibility.
    I drove around and "bedded" the brakes by driving 30 MPH and stopping repeatedly. Hopefully the sliders adjusted the pads. I didn't have the problem yesterday or today so far. Hopefully that helped. If I get another "Service stability System" it's going to the shop and they're replacing the wheel speed sensor/hub under warranty.
    Hopefully in removing it, they'll somewhat service/lube the caliper and take care of that issue too.
Simply register and/or login to remove these advertisements.
  • You may not post replies
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum | kia forte forum | used car savings
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
