| Cadillac Seville / Cadillac Eldorado Forum Forum for discussions regarding the past Seville and Eldorado. | Cadillac Forums: Clunking noise, front end 98 ETC
02-13-07, 02:31 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Clunking noise, front end 98 ETC My 98 Eldorado ETC makes a clunking noise on rough roads (any speed). I put it on the rack and everything is tight except the stabilizer bars have some play in the link ends. My question is, is this a home garage fix and if so any precautions to observe (parts under tension etc?) I have tools and jacks and a pretty good mechanical background. Where is a good place to buy the needed parts other than the local Caddy dealer-- I'm not to thrilled with them. I'm new to the "club" so any help will be appreciated. Thanks. |
02-13-07, 02:32 PM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: Clunking noise, front end 98 ETC i dont see why not
they arnt that hard i didm on my 83 TA... |
02-13-07, 03:06 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1998 SLS - 160,000 mi | | Join Date: Dec 2004 Location: Petoskey, MI Age: 28 | | | Re: Clunking noise, front end 98 ETC End Links are easy to replace and do-able in your garage. I did mine myself. They are about $18 a piece from your dealer. That's probably what your noise is if they are loose.
As for your precautions, raise the vehicle properly with jack stands or a lift. |
02-13-07, 06:00 PM
| | Cadillac Owners Fanatic Cadillac(s): 1997 Seville STS, Black | | Join Date: Aug 2005 Location: Charlottesville, VA | | | Re: Clunking noise, front end 98 ETC This thread brings up one thing I forgot to check on my car this past weekend. I replaced the balljoints and tie rod ends, which helped, but I still have some random clunks in the front end.
Does your car have the sealed balljoint type end links? How do you tell if they're bad? |
02-13-07, 09:57 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Clunking noise, front end 98 ETC I think they are sealed. I had the car on a friends lift and we spent some time checking all the suspension parts and the links were the only thing that had any play at all. I should have changed them then but it was over the holidays and no dealer close by. Any one, do I need to take any tension off the sway bars after the car is jacked up or will the sway bars just slip out (I couldn't get that lucky). |
02-13-07, 10:29 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1998 SLS - 160,000 mi | | Join Date: Dec 2004 Location: Petoskey, MI Age: 28 | | | Re: Clunking noise, front end 98 ETC If you really just have to replace the sway bar end links then you just raise the vehicle, no need to take any tension off the sway bars other than lifting the vehicle...at least that's how I did mine. |
02-13-07, 11:07 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Clunking noise, front end 98 ETC OK thanks a lot for the info. I hope that is all I have to do . |
02-17-07, 03:50 PM
| | Cadillac Owners Connoisseur Cadillac(s): 1997 Eldorado | | Join Date: Apr 2005 Location: Oakland County, MI Age: 26 | | | Re: Clunking noise, front end 98 ETC The tension IS off the sway bar if the wheels are both at the same elevation. Quote:
Originally Posted by iametarq If you really just have to replace the sway bar end links then you just raise the vehicle, no need to take any tension off the sway bars other than lifting the vehicle...at least that's how I did mine. | | | Cadillac Discussion Tools | | |
Censor is ON | | | |
