| Re: Trunk pull down motor Before you replace any electrical part I need to ask, Have you checked for blown fuses, or loose connections at the pull down motor?
The $60 part is the motor, this is probably what you need to replace. The motor is the unit that you see in the trunk. The $200 part is actuator which is found on the truck lid itself.
The way to tell which item has failed (if you have verified that all fuses and connections are fine) is simply to push the trunk release button (preferably in the glovebox), if you hear the "clunk" and you can open the trunk then the actuator is operating properly.
Sometimes if you hold the lever down on the actuator, and repeatedly push down on the lever on the motor; the pull down action will engage. Quickly release both and close the trunk. this will allow you trunk to remain completely closed until you get you new unit.
Hope I have helped in some way, good luck! |
