Cadillac Forums: Service Stability System
  #31 (permalink)
Old 08-15-08, 10:20 PM
Murphyg's Avatar
Cadillac(s): 2001 STS
View Murphyg's Photo Album
Casino Cash: $1703
Re: Service Stability System
Had the Steering Position Sensor changed on my 01 for the service stability message. Message never came back.
Had the Intermediate Steering Shaft changed because of a shuddering in the steering wheel at low speed turns. Apparently the part is a different design. Shuddering went away
  #32 (permalink)
Old 01-31-09, 05:00 PM
Cadillac(s): 2002 escalade
View Ed Sorger's Photo Album
Casino Cash: $275
How do I get the codes? My Service Stability system light stays on every time I drive the car.
  #33 (permalink)
Old 01-31-09, 05:51 PM
submariner409's Avatar
Casino Cash: $20619
If you have a DIC control panel like the Seville/Deville series (3 toggle/buttons just right of the DIC ?) the stickys at the top of this thread page, Northstar Performance, and Technical Tips entitled "How to pull codes" and "Got codes ? Look here" will tell you how. It's all built into the car. No scanner needed - generic scanners miss a lot of codes anyway.
  #34 (permalink)
Old 02-01-09, 09:46 PM
ocgltd's Avatar
View ocgltd's Photo Album
Casino Cash: $1095
Murphyg - could you post the new intermediate shaft part number?
I've got an 01 with a shudder/stickyness when I turn at low speed (feels like something sticks then releases on turn).
I'm planning to do SWPS and Intermediate Shaft this summer...just planning the job.
  #35 (permalink)
Old 02-02-09, 03:49 PM
Cadillac(s): 99 STS
View SwampeastMike's Photo Album
Casino Cash: $4615
Part number for the intermediate shaft ('01 - '04) is: 26079786
A number of GM models used this part. Not sure when, but it was re-designed. Distance between the steering rack and the column is not fixed and the intermediate shaft has to change length. The original design tended to get stuck (thus the "popping" you notice in low-speed, sharp turns) instead of moving smoothly.
  #36 (permalink)
Old 02-23-09, 02:03 PM
Cadillac(s): 2001 SLS, 1997 STS, 71 Eldo
View dalamak's Photo Album
Casino Cash: $745
I get C1287 and C1288, car drives fine, no pulling. should a new SWPS fix this?
  #37 (permalink)
Old 10-18-09, 08:50 PM
Cadillac(s): Deville
View AAZHAAN's Photo Album
Casino Cash: $275
Originally Posted by CadillacSTS2003 View Post
dude
its an easy fix
not a cheap part though
its like 160 bucks i just replaced my dads...
Ok "Dude" How is this an easy fix? I ave a 2000 deville that has the infamous code. Other people are describing the process as complex procedure others stuck on disabling SIRS but you know of an easy fix. Can you please tell me how you performed this tsk? Inquiring minds would definitly like to know more.
  #38 (permalink)
Old 10-19-09, 12:46 PM
Cadillac(s): 1999 Seville
View Mendez33's Photo Album
Casino Cash: $460
I have a 99 SLS, and I just started getting two codes. C1286 and C1287. I know the C1287 is a result of a bad SWPS just like everyone else on this thread, but how exactly is the C1286 connected to this. Could it be that it is just a bad connection? And if so, would that result in getting the C1287 code and not needing to replace the Steering sensor?
Tags: , ,
service, stability, system
