Cadillac Forums: eldo97 - how to check plenum /vacuum leak
Old 12-31-06, 12:49 AM
Cadillac(s): seville 96, Catera 97, eldorodo 97
View john19990's Photo Album
Casino Cash: $1801
Can you please share how to check plenum or how to perform vacuum leak test. My eldo 97 stals when cold start but works perfectly when warm. Where is the plenum? How to test. Where are the 6 plenum nuts?
Thanks
John
  #2 (permalink)
Old 12-31-06, 04:30 AM
View Ranger's Photo Album
Casino Cash: $24216
Re: eldo97 - how to check plenum /vacuum leak
The plenum is the intake manifold. Spray some Brakleen or carb cleaner around the perimeter and listen for an RPM increase. That's where the leak is.
  #3 (permalink)
Old 12-31-06, 04:32 AM
davesdeville's Avatar
Banned
Cadillac(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
View davesdeville's Photo Album
Casino Cash: $250
The plenum is the part of the black thermoplastic intake manifold that all the runners connect to. The runners are what allow air to flow to the intake ports from the plenum.
If you want to see if there's a leak present and find it's general location, get a propane torch. Keep it unlit, but open it up so propane flows out. Then aim it at places you think the leak might be. If the idle smooths out or changes noticeably, you found your leak.
  #4 (permalink)
Old 12-31-06, 10:41 AM
Casino Cash: $1801
Thanks so much for the replies.
Is manifold intake the same that is opened when cleaning TB? I want to check the plenum bolts if tight. I understand that there are 6 plenum bolts. Honestly I dont understand which is the manifold intake. I tried to search any picture of the manifold intake but could not. Any description of intake or picture will help. Thanks again.
John
  #5 (permalink)
Old 12-31-06, 03:50 PM
Casino Cash: $24216
There are some pics somewhere, but I cannot recall where. The TB is bolted to the black thermoplastic intake manifold aka plenum. Remove the silver beauty cover and it will become very obvious.
  #6 (permalink)
Old 12-31-06, 06:49 PM
WarrenJ's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 2001 ETC Sequoia
View WarrenJ's Photo Album
Casino Cash: $510
Wouldn't a minor vacuum leak cause an *increase* in RPM?
John19990, I'd be interested in knowing what has steered you to the plenum as a source of your problem.
Is it hard starting when cold?
Regards,
Warren
  #7 (permalink)
Old 12-31-06, 08:59 PM
Casino Cash: $24216
Yes, that's true Warren. Just guessing here, but maybe on a cold engine it leans it out too much to keep running.
  #8 (permalink)
Old 01-01-07, 01:00 AM
Casino Cash: $1801
Warren,
My Eldo 97 stals after cold start once every few days during the first couple of miles on traffic light. Once engine is warm, it runs great. Once of the posts on this forum something like "rough idle problem solved" indicated a similar issue that was resolved by tightening the loose plenum 6 nuts. I understand that this individual had a similar problem of cold idling. I thought that I might have a similar problem so thought of checking the plenium 6 nuts.
Thanks
John
  #9 (permalink)
Old 01-01-07, 04:37 AM
Banned
Casino Cash: $250
Can we stop calling the whole intake manifold the plenum? The plenum is the open area of the manifold, the runners are the rest, it's not just the plenum..
  #10 (permalink)
Old 01-01-07, 04:45 AM
WarrenJ's Avatar
Casino Cash: $510
Okay, can I be the first to stop calling it that? Please consider it done.
Regards,
Warren
  #11 (permalink)
Old 01-01-07, 06:38 AM
Banned
Casino Cash: $250
You can be the first to stop calling it that, I applaud you for your effort and will give you some rep points
  #12 (permalink)
Old 01-01-07, 04:54 PM
clarkz71's Avatar
Cadillac(s): 1994 Mercedes E420 / 1995 Eldorado/ 2006 Yamaha R1 LE
View clarkz71's Photo Album
Casino Cash: $1100
Here's the manifold. There are 5 bolts on each side, the two inner bolts on each side double as the hold downs for the beauty cover. NOTE: Be advised, the torque is only 89 inch lbs or (7.4 ft lbs)
Tags: , , , ,
check, eldo97, leak, or vacuum, plenum
