| Cadillac Seville / Cadillac Eldorado Forum Forum for discussions regarding the past Seville and Eldorado. | Cadillac Forums: Fpr Pics
12-27-06, 11:25 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1995 Pearl White Diamond Cadillac Eldorado ESC | | Join Date: Apr 2006 Location: North Brunswick, NJ Age: 21 | | | Re: Fpr Pics I can only see a pic in post # 12. I tried reloading the thread, but no pic in post # 6.
I do wish there are pics in the FPR writeup thread.
I started a thread which had pics of my then unknown FPR. You can check them if it helps. http://www.cadillacforums.com/forums...y-95-eldo.html (What are these parts on my 95 Eldo?) |
12-28-06, 12:02 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 1999 STS - diamond white | | Join Date: Dec 2004 Location: Wichita, KS | | | Re: Fpr Pics Good grief, it's on the fuel rail! Between the pic and the instructions provided it should be simple. |
12-28-06, 06:04 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 1994 Mercedes E420 / 1995 Eldorado/ 2006 Yamaha R1 LE | | Join Date: Mar 2006 Location: Clearwater Beach, Florida Age: 46 | | | Re: Fpr Pics OK, here it is again, the FPR is circled in red!!!  |
12-28-06, 06:08 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 1994 Mercedes E420 / 1995 Eldorado/ 2006 Yamaha R1 LE | | Join Date: Mar 2006 Location: Clearwater Beach, Florida Age: 46 | | | Re: Fpr Pics Here's a pic of a 99. The only difference is the 99 has a plastic/nylon fuel rail. As you can see the FPR is in the SAME location.  |
12-28-06, 01:21 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1995 Pearl White Diamond Cadillac Eldorado ESC | | Join Date: Apr 2006 Location: North Brunswick, NJ Age: 21 | | | Re: Fpr Pics Ah! Now I can see the pic in post #6!  |
12-28-06, 01:31 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 1997 Polo Green Cadillac Seville STS | | Join Date: Nov 2006 Location: Georgia | | | Re: Fpr Pics WHAT!!! Why do the pictures show the PCV line ABOVE the plug wires????????? A good way to break it when installing the cover... That PCV line should rest on the molded groves in the intake... Not the plug wires..
And YES, I did COMPLETELY remove the entire PCV line when I did the wires and plugs last weekend.. (To prevent breakage). I also went thru the trouble to reinstall it correctly before I finished.... |
12-28-06, 01:41 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1994 Mercedes E420 / 1995 Eldorado/ 2006 Yamaha R1 LE | | Join Date: Mar 2006 Location: Clearwater Beach, Florida Age: 46 | | | Re: Fpr Pics Quote:
Originally Posted by Gearheaad43 WHAT!!! Why do the pictures show the PCV line ABOVE the plug wires????????? A good way to break it when installing the cover... That PCV line should rest on the molded groves in the intake... Not the plug wires..
And YES, I did COMPLETELY remove the entire PCV line when I did the wires and plugs last weekend.. (To prevent breakage). I also went thru the trouble to reinstall it correctly before I finished.... | No, those grooves are for the injector wire harness. Look again, the same grooves are on the other side of the manifold for the front bank. And I posted 2 different pics, a 98 and my 95. Are they both wrong?..... NO, they aren't. Now, go back and fix your's.
12-28-06, 08:28 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 1997 Polo Green Cadillac Seville STS | | Join Date: Nov 2006 Location: Georgia | | | Re: Fpr Pics Quote:
Originally Posted by clarkz71 No, those grooves are for the injector wire harness. Look again, the same grooves are on the other side of the manifold for the front bank. And I posted 2 different pics, a 98 and my 95. Are they both wrong?..... NO, they aren't. Now, go back and fix your's. | Ummmm Well At first I did add the PCV hose on top like in the pics you have... But the cover would not fit right. So I remembered that my wires were on top on the PCV hose to begin with... So I fixed it back and the cover slid right into place........... BTW those groves are too BIG for the injector harness and just the right size for the PCV hose???  |
12-29-06, 05:41 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 1994 Mercedes E420 / 1995 Eldorado/ 2006 Yamaha R1 LE | | Join Date: Mar 2006 Location: Clearwater Beach, Florida Age: 46 | | | Re: Fpr Pics Coincidence, as I said, the grooves are in the front as well and they are for the harness. Trust me, I've been an ASE certified technician for over 25 years. I got my Eldo with 50K miles, everything was original & thats how it was. I took it for the fuel rail recall & the Caddy tech also put it back like that. Nothing wrong with putting the line under the wires, however my cover fits fine the way it is. |
12-29-06, 10:13 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1995 Pearl White Diamond Cadillac Eldorado ESC | | Join Date: Apr 2006 Location: North Brunswick, NJ Age: 21 | | | Re: Fpr Pics My lines are the exact same as te pic posted in post # 18. Cover comes off and goes back on without any problems. |
01-07-08, 01:12 PM
| | Cadillac Owners Member | | | | | Re: Fpr Pics what type of problems could this give you? im asking because i had a fire under my hood, and the vacuum line melted the one coming from the bottom has a hole melted to it and i had to replace something else close to there i believe its the pcv for dirty air...i tried to make one and all my engine will crank but not turn over or any ideas to check things will help
thanks |
01-07-08, 03:52 PM
| | Cadillac Owners Connoisseur Cadillac(s): 2000 STS, Past : 99 STS, 94 STS | | Join Date: Aug 2004 Age: 30 | | | Re: Fpr Pics Anyone have a pic of 2000 + model ?
Mine is in need of replacement I am getting an ocasional extended crank when starting up. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
