Picked it up this morning.
Better shape cosmetic wise than I expected
. Still needs cleaning in some areas (I detail show cars, So I'm picky) Immediately after starting, came the dreaded message across the DIC.
"Service Stability System"
UGGHHH!!!!!!!!!!!!!!
So after checking the fluids, I started off on my way to bring it home.. Coolant Temps stayed right dead center.
,... No oil light, no low level lights.. So after it warmed it some, I got on it on the freeway (60-90) passing gear a couple times. And it was pretty responsive. But I thought not as quick as my Supercharger 3800 V6 in the Grand Prix.
Anyhow, I drove it 55 miles on the interstate. Got off the exit and stopped at the light off the exit ramp. Smoke starting coming out of the hood on the left side, On green, I pulled into a vacant lot and popped the hood to investigate the smoke. It smelled like coolant and it appeared to be coming from the left/ back side of the engine, just behind the Throttle body. The smoke cleared up... I drove it another 30 miles ...No smoke.
What the hell was that?
Upon arriving home, I ran the Diagnostic Mode. DTC History indicated:
PCM P0603 - Control Module Long Term Memory Reset
RSS C1760 - Left Front Position Sensor Input Fault
RSS C1761 - Right Front Position Sensor Input Fault
PZM B1971 - Inadvertent Power
IRC B1740 - Driver Seat Front Down Switch Malufunction
IRC U1129 - Loss of Communication with AMP.
Questions:
1. Are the L & R Position Sensors replaceable? Or do the struts need replacing?
2. What does Inadvertent Power Mean?
3. Is the AMP bad?
4. What do you guys think caused the smoke?
I'll have pictures in a couple days after I have time to really detail it to death!!!! I'd appreicate any help from you folks on here!!!
