| Cadillac Seville / Cadillac Eldorado Forum Forum for discussions regarding the past Seville and Eldorado. | Cadillac Forums: How to Shut off DRLs (and add digital coolant temp and speedo in the dic)
11-09-06, 04:25 PM
| | Cadillac Owners Connoisseur Cadillac(s): '98 STS | | Join Date: Sep 2003 Location: Atlanta area | | | Re: How to Shut off DRLs (and add digital coolant temp and speedo in the dic) I can guarantee for '98 Seville (and quite likely '98 to '04) that pulling the DRL/FOG fuse is not the way to do it. And pulling the DRL relay will disable your high beams forevermore.
Download the file at Post #1 on this page have fun. Some surgery required! http://caddyinfo.ipbhost.com/index.php?showtopic=4797 |
11-09-06, 04:28 PM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: How to Shut off DRLs (and add digital coolant temp and speedo in the dic) thought so
ipc overrides is the only SAFE way to do it without hacking the car |
11-10-06, 03:08 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1998 SLS - 160,000 mi | | Join Date: Dec 2004 Location: Petoskey, MI Age: 28 | | | Re: How to Shut off DRLs (and add digital coolant temp and speedo in the dic) My dealer has agreed to try this on my 98 Seville with the Tech II Tool. I showed him a print out of this thread, and he thinks I am a bit weird. Oh well. It's scheduled for next Tuesday.
I am going to try to be there and see if they will let me watch them try, but I don't know if i'll be able to get out of work.
I will post back with the outcome next Tuesday! My fingers are crossed. |
11-10-06, 03:23 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2003 STS, 1993 Deville, 1985 Deville | | Join Date: Jul 2003 Location: Wyoming | | | Re: How to Shut off DRLs (and add digital coolant temp and speedo in the dic) Quote:
Originally Posted by CadillacETC1997 you also lose highbeams ive herd with that | Nope. Pulling the DRL fuse disables only the DRLs. Everything else continues to function normally.
That's what I did. It works great. Remember that I'm referring to the 2003 STS, not the older Sevilles. |
11-12-06, 05:48 PM
|  | Cadillac Owners Fanatic Cadillac(s): 1996 Cadillac Seville STS | | Join Date: Jul 2005 Location: Ontario Canada Age: 39 | | | Re: How to Shut off DRLs (and add digital coolant temp and speedo in the dic) RE:
IPS03 Option C
- RSS installed (128)
-Premium Unleaded Fuel Only -
-Graphic supression (digital) (64)
-Daytime running lamps enabled (32)
-Cellular Telephone Installed (16)
-BTSI message suppression (4)
-Options not set (2)
-FUEL LEVEL LOW message suppresion (1)
Just check this and I have a total of 92. I wanted to find the cell status. I can't seem to add the numbers up to get 92. Any suggestions?
Thanks |
11-14-06, 10:23 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 1998 SLS - 160,000 mi | | Join Date: Dec 2004 Location: Petoskey, MI Age: 28 | | | Re: How to Shut off DRLs (and add digital coolant temp and speedo in the dic) Quote:
Originally Posted by CadillacETC1997 you can
follow same steps with modifiy
only you need a tech 2!!! | FAILURE!! on 98 Seville
I just got back from my Dealer. I printed out this whole thread and they said they would try it with the Tech II. They could not do it. He said he went through all the various computers, etc but could not find what was posted at the top of this thread.
Do you have instructions or a step by step for the Tech II that I can give them? If someone has a Tech II by some off chance and can provide step by step how to do it with that device my dealer will do it.
They didn't charge me for trying...I'll send ewill3rd a PM about it maybe he knows... |
11-14-06, 12:27 PM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: How to Shut off DRLs (and add digital coolant temp and speedo in the dic) i know theres a way
damn it i used to have it i was pretty sure it follwed the same ideas by going into the ipc and then overides then modifing them
just like how on 97 you can program your keyless remotes via the dic but on 98+ you require the tech 2 to program them
ill see what i can dig up |
11-14-06, 01:41 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1998 SLS - 160,000 mi | | Join Date: Dec 2004 Location: Petoskey, MI Age: 28 | | | Re: How to Shut off DRLs (and add digital coolant temp and speedo in the dic) thanks, etc1997! |
01-27-08, 01:51 PM
| | Cadillac Owners Connoisseur Cadillac(s): 98 sls | | | | | Re: How to Shut off DRLs (and add digital coolant temp and speedo in the dic) Quote:
only you need a tech 2!!! | how is this done with a tech 2 |
01-27-08, 04:04 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: How to Shut off DRLs (and add digital coolant temp and speedo in the dic) Crown Vic, What are you trying to do ? There are 4 different operations being discussed in this thread: RPM, Temp, speedo, and DRL. (Modifying the DIC display won't work in a '98 +, while pulling fuse 24 works for DRL only.) |
01-27-08, 04:17 PM
| | Cadillac Owners Connoisseur Cadillac(s): 98 sls | | | | | Re: How to Shut off DRLs (and add digital coolant temp and speedo in the dic) i want DRLs GONE
****ers gave me away after chasing the goddang asshat that keeps taggin my garage trying to sneak up on them.
I would like temp as well |
01-27-08, 04:33 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: How to Shut off DRLs (and add digital coolant temp and speedo in the dic) Crown Vic, Read my post ^^^ ! DRL fuses and relays are in the engine room box. Fuse 24.
01-27-08, 04:37 PM
| | Cadillac Owners Connoisseur Cadillac(s): 98 sls | | | | | Re: How to Shut off DRLs (and add digital coolant temp and speedo in the dic) note my 2nd question.
That fuse is in WHAT fusebox? | | Cadillac Discussion Tools | | |
Censor is ON | | | |
