Results 1 to 3 of 3
Thread: How to check that cooling fans are turning on?
    Nov 2003
    California
    39
    So i am starting to wonder if my cooling fans ever come on. Every time I have had the hood open with engine running I have NEVER heard/felt the cooling fans come on. I have had the hood open after idling for 10 minuets, freeway driving and around town driving. Sometimes with the AC on.
    Also the temp gauge is always just past the middle mark of its full sweep. It seems like it should be a little lower.
    Is there a way to manually test that any solonoid in the loop is working and that the electric motors both work?
    Thanks,
    Will
    Oct 2003
    Ohio
    334
    Re: How to check that cooling fans are turning on?
    If it's not over heating they are working. The first thing to check would be to turn the AC on and look. They should both always be on with the AC.
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Quote Originally Posted by stswillie
    Thanks,
    Will
    If it hasn't overheated they are likely fine. The cooling fans rarely need to actually run, especially in cold weather.
    Just let the engine idle for a while. They will eventually come on. Watch the temp gauge and it will creep up quite a bit before the fans come on due to coolant temp. The coolant needs to get to 225-230 before the fans will come on. Below that they are just not required. It takes a long time in cold weather for the coolant to get up to that level. Put a piece of cardboard in front of the rad to make it warm up quicker to see them turn on.
    The fans are also controlled by the AC compressor operation. The AC condensor needs pretty continous air flow over it when the AC is on so the fans will run most all the time when the AC is on regardless of coolant temp....but....the HVAC must be in AUTO and the ambient temp MUST be above 40...or the AC compressor is disabled. If the ambient temp (shown on the outside air temp display) is around 40 or colder the AC compressor is disabled and the fans will not come on due to AC load...they will come on due to coolant temp only.
    Sooo.... it is common to see the coolant get hottter on idles in the winter than in the summer many times. In the summer the AC is on so the fans are on regardless...and the coolant stays cooler due to the air flow of the fans. In the winter, only the high coolant temp is turning the fans on so it is common to see it creep higher than it does in the summer.
  • You may not post replies
