Help! Emergency Brake Stuck On
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, Help! Emergency Brake Stuck On in Past Cadillac Vehicle Discussion; 1994 STS I had the car on jack stands with the emergency brake on for engine removal. The engine, battery, ...
    Lawrence's Avatar
    Lawrence is offline Cadillac Owners Fanatic
    Oct 2003
    Ohio
    334
    1994 STS
    The engine, battery, PCM, etc. is out of the car.
    Today I wanted to push it out of the garage to clean the engine bay but the emergency brake it stuck on.
    Any guess' as to how to release it?
    JJhomer83's Avatar
    JJhomer83 is offline Cadillac Owners Connoisseur
    Sep 2003
    Bucks County, Pa
    34
    1,805
    Re: Help! Emergency Brake Stuck On
    Quote Originally Posted by Lawrence
    1994 STS
    if its the same as my 92 eldo its simple you have to reach your hand up by the peddle and pull a lever towards you and it will release. hope that helps
    Lawrence's Avatar
    Oct 2003
    Ohio
    334
    JJHomer83.......Yes, thats it. Thanks for the quick reply. I found a diagram in the owners manual.
    I really can talk and chew gum at the same time.
    Thanks Agian,
    Lawrence
    JJhomer83's Avatar
    Sep 2003
    Bucks County, Pa
    34
    1,805
    Thanks Agian,
    Lawrence
    not a problem,
    hope everything works out well for you, :coolgleam
    Chuck C's Avatar
    Chuck C is offline Cadillac Owners Connoisseur
    Jan 2003
    NE Ohio
    1,531
    the vacuum pump/hydraulic thingy that makes it pop out might have gone bad...that's what happened to mine. They quoted $250 for a replacement pump. I just use the top of my foot to pull it out.
    El Dobro's Avatar
    El Dobro is offline Cadillac Owners Connoisseur
    Sep 2003
    1,471
    $250.00 ?!? The release for that car is only $21.00.
  9. Remove Advertisements
