Results 1 to 2 of 2
Thread: Swapping front seville seats
    Dec 2003
    42
    Can 1998 front seats be easily installed into a 1996 seville with no complications with the wiring or track. I want to know because i do not have heated seats and there are some 98 seats out there with heat. Thanks for any help.
    Ps does anyone know the interior code for the light nuetral color interior? Where would i find this code? There is a sticker missing from my driver side door, so anyplace else? thanks
    Oct 2003
    Ohio
    334
    Re: Swapping front seville seats
    Not easily. It would require alot of wiring. They are integrated into the whole OBDII system.
    You would be better off going with after market. A lot less expensive to replace when bad as well. You could aquire the factory switches and wire them to the after market heaters so it as least looked OEM.
    Check with your local mobile audio video stores. I think they are usually about $600 installed.
  • You may not post replies
