  Follow CadillacOwners on Twitter
Cadillac Forums: Wire Harness 94 STS
Old 09-25-06, 05:03 PM
View only1kairi's Photo Album
Casino Cash: $275
Wire Harness 94 STS
Can I replace my own engine wire harness without the required expert knowledge? I'm thinking simply replace all the areas as I go along. I was able to replace my own heater core with out any problems and I saw the PCM module with the wire harnes in there. Or do I need to drop the engine and transmission? I have a 94 STS and I own the Service Manual.
  #2 (permalink)
Old 09-26-06, 12:07 PM
Cadillac(s): 94 ETC,97 STS
View zonie77's Photo Album
Casino Cash: $8579
Re: Wire Harness 94 STS
Why are you changing it? Are you replacing it with a different factory harness or repairing sections of it? Why? What problems are you having?
There is little "expert" knowledge to replace with a factory harness. Most connections are unique so it's hard to plug things in to the wrong spot.
If you are replacing sections you should be able to solder and use shrink tubing. I would recommend that over crimp connectors.
  #3 (permalink)
Old 09-26-06, 12:51 PM
Casino Cash: $275
Well I took it to the dealer and they said the entire wire harness was severly damaged. They recommended a new one but that part is discontinued, so I was going to get one in better condition from the junkyard.
  #4 (permalink)
Old 09-26-06, 12:58 PM
davesdeville's Avatar
Banned
Cadillac(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
View davesdeville's Photo Album
Casino Cash: $275
If somehow the entire wiring harness is severely damaged you'd probably be better off dropping the powertrain & subframe. It doesn't seem likely that the whole thing could be severely damaged unless the car was on fire or something like that.
  #5 (permalink)
Old 09-26-06, 01:31 PM
Casino Cash: $275
ok, so I guess the frame has to be lowered and thats something I really do want to get involved in. I can replace a wireharness but I am afraid they may be some places I can't reach. Apparently someone jimmied alot of the wiring to the point of no return to fix the throttle control and the dealer thinks its affecting the transmission as well.
  #6 (permalink)
Old 09-27-06, 02:51 AM
Casino Cash: $8579
Were wires cut?
You can change the harness without dropping the engine. If you were to drop or tilt the engine some of it would be easier to get to.
You can replace the whole harness without any special training. Just carefully remove and pay attention to where everything hooks up.
  #7 (permalink)
Old 10-03-06, 08:59 PM
Banned
Casino Cash: $275
I went ahead and took a pic of my 95 ETC's engine wiring harness lying on the driveway, just for reference. I'm going to be putting it back in tomorrow (and probably for a couple more days) - it's not gonna be very fun. At least my engine's back on the subframe..
  #8 (permalink)
Old 10-03-06, 09:02 PM
View Ranger's Photo Album
Casino Cash: $27171
  #9 (permalink)
Old 10-04-06, 10:55 PM
Casino Cash: $275
Davesdeville did you have to remove the engine or transmission to get the wire harness in there? I guees I would have to take 3 days off from work to under take this task. I wish they had a remanufactor that made these things. I got mine from a junkyard.
  #10 (permalink)
Old 10-05-06, 06:17 AM
Banned
Casino Cash: $275
I dropped the subframe with engine and trans attached to it, in an effort to replace the subframe with a non-bent one, and the engine oil pan... I only pulled the harness out in order to facilitate transferring everything over to the new subframe. I haven't started to put the harness back in yet (I'll be starting in about 8 hours,) so when I do I'll post back here with what I think about doing it in the car...
  #11 (permalink)
Old 11-08-06, 09:24 PM
Casino Cash: $275
I put in my wire harness (with a chrome loom) without removing the engine. I must admit my hands really do hurt. I think they are swollen from squezzing them into so many tight places. Both A & B crankshft sensors plus the temperture sensors were the hardest to get to. I under up removing my oil filter and cleaning my throttle. I did ended up with 4 codes after words, since its raining im soaking my hands.
My Question - LOL
But the only one code I have to figure out is the p034 -- I swore I had a new MAP sensor installed and its a remanufactored engine from jasper. In order to get the wire harness over, I did mess with the adjustments of the shaft under the throttle and TPS sensor. Would that affect the Manifold in anyway?
BTW it looks sweet, and I can't wait to put this baby on the road.
Tags: , ,
harness, sts, wire
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
