| Cadillac Seville / Cadillac Eldorado Forum Forum for discussions regarding the past Seville and Eldorado. | Cadillac Forums: How hard is it to replace front motor mount on '03 STS?
01-30-07, 09:56 AM
|  | Cadillac Owners Master Cadillac(s): 1989 STS / 2001 DTS / 2002 DTS | | Join Date: Apr 2005 Location: Upstate NY | | | Re: How hard is it to replace front motor mount on '03 STS? Thanks for the info the heat shield.
Danbuc, you did the billet mount right? I remember talking to you about that.
__________________ Ownership:
89 STS (1 of 1893) - FOR SALE
02 Blue Onyx DTS 01 DTS: Custom installed Volant CAI Custom PCM Body color engine components Cruiser Alloy wheels EBC brakes Eibach springs
Corsa exhaust Sportwing Spoiler Semi-custom interior Custom quad Hi-Beams Future Plans: More interior work. Memberships: National and regional Cadillac & LaSalle Club Proud Volunteer - Northstar Tuning Project ---------------------------- |
01-30-07, 05:58 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1998 STS/2006 M6 GTO | | Join Date: Mar 2004 Location: Mahwah, NJ Age: 24 | | | Re: How hard is it to replace front motor mount on '03 STS? Quote:
Originally Posted by codewize Thanks for the info the heat shield.
Danbuc, you did the billet mount right? I remember talking to you about that. | Yeah, the company that bought out RSM when they folded said they stopped making them because of too much vibration transfer from the engine. To be honest, it's really not that bad at all. I only notice it a slight bit the first week or so after I installed it, but I'm used to it now. I'd have to drive one without ti to notice a difference. |
03-11-07, 01:05 PM
|  | Cadillac Owners Member Cadillac(s): 2000 Deville DTS | | Join Date: Dec 2005 Location: San Antonio, TX Age: 41 | | | Re: How hard is it to replace front motor mount on '03 STS? Quote:
Originally Posted by Cad tech It is rather easy to replace...jack up on unibody frame rail both sides, remove both front bolts on subframe it will drop, remove 18 mm on engine mount, lower subframe even more, remove trans to engine brace (just a little bar), and 3 remaining bolts on engine mount, pull it down let top end slide out then worm the rest out prying down on lower subframe...replace mount reinstall, if you have ride hieght sensors reattach links... | I just replaced my front motor mount on my DTS. Pretty much like Cad tech said. Not too hard of a job to do. I replaced my mount with GM part and used the heat shield kit. The hardest part actually for me was maneuvering the mount and brace out after everything was unbolted. I did not remove the fans as it was suggested. Another tip I should mention is to use a jack with a block of wood under the oil pan to lift the engine to give yourself some extra room to manuever the brace out. No special tools were needed, but I would suggest getting a long extension to get to the 2 bolts that mount the brace to the engine. Here are some pictures (everyone loves pictures) of the new mount and shield and of the old mount. As you can see in the pictures, my old mount was a complete failure and yes, the fluid from it went everywhere when I turned it over. Have a shop rag ready to sop it up when you are trying to get it out. My mount was to the point that you could actually see/feel the engine rocking in the cradle. The difference of before and after is VERY noticeable. No more of the big "clunk" when putting the vehicle into gear, or the knock/bump during on-off acceleration, and it is silky smooth on the highway with no vibration. I would also attribute the bad mount to the premature failure of the half-axles that I replaced. I have that posted in Tech Tips http://www.cadillacforums.com/forums...placement.html (CV axle Halfshaft replacement) |
07-22-09, 01:36 PM
| | Cadillac Owners Member Cadillac(s): 99 seville | | Join Date: Jul 2009 Age: 39 | | | Re: How hard is it to replace front motor mount on '03 STS? Although this is an old thread.....Very nice write-up Domino. thank you! |
09-17-09, 12:43 AM
| | Cadillac Owners Member Cadillac(s): 1998 s.t.s | | Join Date: Jul 2009 Age: 44 | | | Re: How hard is it to replace front motor mount on '03 STS? drop front sub frame down take bolt loose from the head remove bottom nut remove from the front |
09-17-09, 10:26 AM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: How hard is it to replace front motor mount on '03 STS? Support the engine by putting a block of wood and jack(stand) underneath the steel plate tha connects the engine and transmission.
The N* oil pan is not a heavy casting and too much pressure on the bottom of the pan will really ruin your day.
__________________ Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
