Cadillac Forums: How hard is it to replace front motor mount on '03 STS?
  #16 (permalink)
Old 10-26-06, 07:07 AM
ewill3rd's Avatar
Cadillac Technician
Cadillac(s): none
View ewill3rd's Photo Album
Casino Cash: $16917
Re: How hard is it to replace front motor mount on '03 STS?
Yes, those break quite often.
We just call it the "front" motor mount in the shop and everyone knows what we are talking about.
On some cars there is a bulletin to also install a heat shield to help prolong the life of the new mount. It's close to the exhaust manifold so it's supposed to keep the heat off of it from the manifold. Time will tell if it works.
That is primarily for Deville though.
  #17 (permalink)
Old 10-26-06, 01:10 PM
Cadillac(s): 2000 SLS
View Rainman15's Photo Album
Casino Cash: $250
I just did mine on my 00 SLS. The part from Autozone was 103 with tax and a local shop did the labor for $100. No big deal.
  #18 (permalink)
Old 01-17-07, 12:47 PM
Cadillac(s): 99 STS
View Blazin Bill's Photo Album
Casino Cash: $325
Question Re: How hard is it to replace front motor mount on '03 STS?
Okay, I read through this whole thread and I'm a bit confused on the terminology ...which mount is the one that commonly fails? I know it's the one that is located front, center, behind the radiator, but what's the part #?
25710672 is the front engine mount.
25696073 is the center engine mount.
I was at the dealer last week and they discovered the mount (located front, center, behind the radiator) on my 99 STS was broken.....
I greatly appreciate the help.
  #19 (permalink)
Old 01-17-07, 01:29 PM
Cad tech's Avatar
Cadillac(s): 03 STS, 97 STS, 58 Eldo
View Cad tech's Photo Album
Casino Cash: $250
the front engine mount is the culprit, (left)......is it leaking oil or is there a sevear bump when shifting between P, R, D?????At any rate get it replaced it causes damage to other mounts and if you really let it go could cause problems in shift adapts in trans....
It is rather easy to replace...jack up on unibody frame rail both sides, remove both front bolts on subframe it will drop, remove 18 mm on engine mount, lower subframe even more, remove trans to engine brace (just a little bar), and 3 remaining bolts on engine mount, pull it down let top end slide out then worm the rest out prying down on lower subframe...replace mount reinstall, if you have ride hieght sensors reattach links...
  #20 (permalink)
Old 01-17-07, 02:04 PM
Cadillac(s): 99 STS
Casino Cash: $325
So is that Part #: 25710672, just trying to be sure before I order it from gmpartsdirect. The only symptom of the broken mount is a knock that I heard under heard accleration. No leaking oil. No bump when shifting.
  #21 (permalink)
Old 01-17-07, 09:49 PM
Cad tech's Avatar
Casino Cash: $250
does it feel or sound like it is righ under you or towards middle of car???? if it is there is a brace there that the exhaust hits because the mount is starting to fail you can bend the brace down for temp fix..I am pulling up this part # from GM 25696073.
  #22 (permalink)
Old 01-29-07, 08:46 AM
View carguy's Photo Album
Casino Cash: $325
I am in the process of doing this and still can't get to the bolt(s) on the top of the mount. I have already dropped the cradle and removed all the bolts on the engine mount bracket except for the ones bolting to the block. Would this make it easier?
  #23 (permalink)
Old 01-29-07, 09:30 AM
ewill3rd's Avatar
Cadillac Technician
Cadillac(s): none
Casino Cash: $16917
Sometimes the upper bolts are more easily accessed from above, you might find it beneficial to remove the cooling fan(s) for access.
I have some tools that I bought that allow me to get them from underneath easily but they can be a challenge without dropping some serious bucks on what you need. The fans are usually easy to get out but you may have to unhook the trans cooler line and slide the fans out that way for enough room to work.
  #24 (permalink)
Old 01-29-07, 07:37 PM
danbuc's Avatar
Cadillac(s): 1998 STS/2006 M6 GTO
View danbuc's Photo Album
Casino Cash: $2611
I got the upper bolts off with a 24" extension and a universal joint. It was tedious work, but easier that reaching your hand all the way up there....of course my car was still hot since I had just finished driving it. If it's cool, it's easier to do without burning one's self.
  #25 (permalink)
Old 01-29-07, 08:08 PM
codewize's Avatar
Cadillac Owners Master
Cadillac(s): 1989 STS / 2001 DTS / 2002 DTS
View codewize's Photo Album
Casino Cash: $14380
The one on my DTS cost me $412. Don't bother fixing it. It's only going to brake again. Unless you're going to replace it with something solid you're wasting your time and money.
Ownership:
89 STS (1 of 1893) - FOR SALE
02 Blue Onyx DTS
01 DTS:
Custom installed Volant CAI
Custom PCM
Body color engine components
Cruiser Alloy wheels
EBC brakes
Eibach springs
Corsa exhaust
Sportwing Spoiler
Semi-custom interior
Custom quad Hi-Beams
Future Plans: More interior work.
Memberships:
National and regional Cadillac & LaSalle Club
Proud Volunteer - Northstar Tuning Project
  #26 (permalink)
Old 01-29-07, 11:58 PM
danbuc's Avatar
Casino Cash: $2611
Mine isn't going to break again...EVER! Of course the only company who maid it doesn't anymore, so I guess that's it. Those hydraulic mounts don't last too long if you run the car hard...which is a shame.
  #27 (permalink)
Old 01-30-07, 06:43 AM
ewill3rd's Avatar
Cadillac Technician
Cadillac(s): none
Casino Cash: $16917
Not that it will help most of you, but for Deville, they released a heat shield to help protect the mount from the heat at the nearby exhaust pipe.
The part number is 15804790 but it is not designed to fit Seville.
  #28 (permalink)
Old 01-30-07, 08:08 AM
Cadillac(s): '98 STS
View JimD's Photo Album
Casino Cash: $18483
Do you have a gut feeling that part would make a reasonable starting point to fabricate a heat shield for a Seville?
  #29 (permalink)
Old 01-30-07, 08:41 AM
ewill3rd's Avatar
Cadillac Technician
Cadillac(s): none
Casino Cash: $16917
Off the top of my head I don't recall the main difference between the two.
If I get one in I will try to take a look, don't hold it against me if I forget.
  #30 (permalink)
Old 01-30-07, 09:02 AM
Casino Cash: $18483
I understand the forget part. The 2nd thing to fail is the memory. And I can't remember what the 1st thing was.
Tags: , , , ,
front, hard, motor, mount, replace, sts
