Help Please RE:Power Tilt Steering 00 STS
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
Cadillac Seville / Cadillac Eldorado Forum Discussion, Help Please RE:Power Tilt Steering 00 STS in Past Cadillac Vehicle Discussion; Hey guys, I need some help. I have a problem with my Power Tilt and Telescopic Steering for my 00 ...
    jsorensen is offline Cadillac Owners Member
    Automobile(s): 00 STS
    Jul 2006
    LakeSide, Hawaii
    7
    UnhappyHelp Please RE:Power Tilt Steering 00 STS
    I have a problem with my Power Tilt and Telescopic Steering for my 00 STS. The steering column is stuck in the exit position.. I tried to adjust it manually and all you hear is a "clicking sound", like its trying to work...anyone with suggestions, i checked the fuses....tried unplugging battery..no luck....Thanks again..
    Jul 2006
    LakeSide, Hawaii
    7
    Re: Help Please RE:Power Tilt Steering 00 STS
    Bump
    68
    81,894
    Sounds like it is mechanical and internal. Stripped gear or something on that order. Some exploratory surgery in in order.
    Sep 2003
    Metro ATL
    4,854
    Pull the trouble codes; you are looking for a "B" code.
    Jul 2006
    LakeSide, Hawaii
    7
    Thanks guys, I pulled the code today, and it gave me:
    B2512 - Strng Wheel Controls Illegal A/D Values
    I have no clue what this means, any suggestions? Thanks again.
    68
    81,894
    Just a guess, but A/D may be Actuator/Drive. I would suspect a bad actuator.
    turbojimmy's Avatar
    turbojimmy is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
    Apr 2004
    New Jersey
    3,963
    The clicking is probably from the module. It sounds like it's become confused about the limits of travel. You can reset it by holding the button for a few seconds (I think 5-8 seconds) and then letting the column travel in that direction to the stop. Do it in each direction and it should be okay (unless it's lost track of one of the potentiometers that sense the limits).
    Jim
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by jsorensen
    This might be useless information, but my '98 Seville Service Manual says B2512 is a fault with the switches at the 9:00 and 3:00 o'clock wheel positions. From the diagram, I would expect A/D to be analog/digital.
    And, the DTCs for tilt/telescoping steering column control faults would be B2853, B2858, B2873, and B2878.
    Dooman's Avatar
    Dooman is offline Cadillac Owners Enthusiast
    Automobile(s): 1999 Black and Tan STS
    Mar 2004
    753
    Mine stopped working last week also, but I get no sounds. Thank goodness it stopped in the down position and the telescopic part works, just not tilt..
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Quote Originally Posted by Dooman
    You should get a faint clicking from the module. It would be unusual for the module to fail. If it works one way but not the other you probably had a motor go bad. There are 2 (one for tilt, one for telescope) and they're identical.
    Jim
    Jul 2006
    LakeSide, Hawaii
    7
    Quote Originally Posted by JimD
    Do you think the problem is a short in the wire or some other elec. prob?
    Thanks for all of your help everyone....
    Sep 2003
    Metro ATL
    4,854
    Clearly the DTC you are seeing does not apply to the problem you are describing.
    If it was my car, I would disconnect both battery terminals (negative first) and then put a wrench on the large cable junctions under the rear seat and the large lug aft of the fuse/relay box under the hood. Take your time.
    Clean up the battery terminals and the cable ends and reconnect the battery cables (positive first).
    Clear the codes and see what happens.
    foxman388 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2006
    5
    ExclamationRe: Help Please RE:Power Tilt Steering 00 STS
    Hello all, Im brand new to the caddy area, Ive been on corvetteforums for a while but just bought a 98 diamond white sts, wow what a car....the only thing i can really find wrong w/ it is the power telescoping feature of the column is inop...from what you guys have said i'm guessing its probably an actuator, although I get no "click" noise from a control module or anything....but the power tilt works great!....any ideas? all help is greatly appreciated...how hard is the actuator to replace? thanks guys
    andy
  16. #14
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Quote Originally Posted by foxman388 View Post
    andy
    Hold the button down for 5-8 seconds in the up or down position and see if it tries to move. You should at least be getting a click from the module (you may not be able to hear it with the trim in place though). The actuator (motor) is not hard to replace. They're bolted to the steering column. You have to take the knee bolster and some other insulating trim down to get to them.
    Jim
  17. #15
    cl8525 is offline Cadillac Owners Member
    Automobile(s): 99 black on black STS
    Sep 2010
    18
    I know this tread is old but if the relay is clicking do I need to change the module or the actual device (box)that you hold to telescope? Mine is clicking and I tried the 5-8 sec option this did not work. Also is the module the little white box with the plugs going into it that is under the steering column. Kind of hard to access. ALso would a junkyard piece be recommended? How much are they. Maybe someone can link a ebay listing so i can see what i need to change. Steering will not go up or down in or out. Just clicking relay sound.
  18. Remove Advertisements
