Service ride control? - seville 96 - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
Cadillac Seville / Cadillac Eldorado Forum Discussion, Service ride control? - seville 96 in Past Cadillac Vehicle Discussion; Nice N*. I have added this to the sticky....
  1. #16
    69
    82,177
    Re: Service ride control? - seville 96
  2. #17
    john19999 is offline Cadillac Owners Fanatic
    Automobile(s): Seville STS 2001, Eldorado 1997
    Jun 2008
    Chicago, IL
    394
    I pulled codes. These are RS0036 History, RS0037 Current, and RS0061. Is there any link where I can read what does these codes mean. I am trying to get some resolution on Service Ride Control which is quite intermittent. Any idea please about these codes.
    Thanks
    John
  3. #18
    69
    82,177
    '96 was a mix of OBDI and OBDII codes. Those are OBDI.
    http://myweb.accessus.net/~090/dtcobd1.html
  5. #19
    Jun 2008
    Chicago, IL
    394
    Thank you Ranger.
    The code RS0061 means - Right Front Position Sensor Fault.
    Which sensor is being referred? How to find "Right". Is it when you stand in front of car, and then towards your right or is it when sitting on the driver seat, then Right hand side front. I will appreciate info please.
    Thanks
    John
  6. #20
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Quote Originally Posted by john19999 View Post
    Thank you Ranger.
    Thanks
    John
    It always refers to when you're sitting in the drivers seat. So RF = Passenger side front.
    For the RS0036 and RS0037, usually the short is internal to the compressor, and good luck finding parts to rebuild it. I would just replace the compressor.... However, just to be safe, check your fuses first. One may be blown.
    For the RS0061, I would just clear the code first and see if it comes back. A lot of times it's a computer fart. If it comes back, then you should look into it further.
  7. #21
    N*Caddy's Avatar
    Nov 2006
    Toronto, Canada
    38
    6,405
    On RS0061 I would start by inspecting the connector and the wire harness from EBTCM to the wheel. It is not normal to show up unless some intermittent contact.
    RS0036 and RS0037 are what is causing the "Service ride control" message. Also inspect/clean the harness (connectors) fist.
    Now you know EXACTLY what is wrong with the car no point throwing randomly parts to the issue.
  8. #22
    caddydaddy83 is offline Cadillac Owners Member
    Automobile(s): 1997 cadillac seville
    May 2010
    34
    1
    hey i got a few codes i need to be read for a 1997 Cadillac seville sts if anyone can help thanks in advance..
    Y1300
    B1983
    B2144
    B2119
    B2120
    B0856
    B1982
    C1738
    C1760
    C1783
    C1785
    B1552
    P0174
    P0441
    P1644
  9. #23
    69
    82,177
    Please don't hijack threads. You won't get much help as the title is not descriptive of your problem. Start a new thread and list the DTC definitions with the codes.
    http://myweb.accessus.net/~090/dtcobd2.html
  10. #24
    ajgandrg is offline Cadillac Owners Member
    Automobile(s): El Dorado Touring Coupe
    May 2013
    Southern California
    12
    I have a "Service Ride Control" message on my display - when I run through the codes here is what appears:
    1996 El Dorado Touring Coupe
    No IPC Code
    No ACM Code
    No SDM Code
    No TCS Data
    No PZM Code
    No CCP Code
    PCM0325 History
    RS0026 History
    RF2560 History
    IP1740 History
    PC0603 History
    PCM?
    Any insight to the meaning of these codes would be greatly appreciated...?
  11. #25
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,569
    read the thread directly above yours -
    and follow that advice -
    start your own thread -
    codes are meaningless with definitions -
    no one has them all memorized -
  12. Remove Advertisements
