| Cadillac Seville / Cadillac Eldorado Forum Forum for discussions regarding the past Seville and Eldorado. | Cadillac Forums: Temp Gauge
05-27-06, 03:32 PM
| | Cadillac Owners Member | | | | | Temp Gauge Greetings,
I just bought a 2003 Cadillac SLS with 27,000 miles. Sometimes sitting in traffic on a warm day, the temp gauge goes alittle over the halfway point (normal operation temp) but goes back to the halfway point once the car starts moving again. Is this considered normal? Just want to make sure.
TIA! |
05-27-06, 04:17 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 94 Deville, 2000 STS, 2005 Escalade 2WD | | Join Date: Jan 2003 Location: Portland, ME Age: 28 | | | Re: Temp Gauge If it's just a hair over the half way mark, don't worry about it. Mine and all other Sevilles will do that.
Congrats on the SLS! |
05-27-06, 04:18 PM
|  | Cadillac Owners Fanatic Cadillac(s): 02 STS | | Join Date: Jun 2005 Location: new york Age: 36 | | | Re: Temp Gauge its happened to me a couple of times on a hot day nothing to woory about |
05-27-06, 10:47 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2000 Seville STS | | Join Date: May 2004 Location: Chicago Area Age: 26 | | | Re: Temp Gauge Heh.. same thing started happening with my STS.. Though it JUST started happening..
MacK |
05-27-06, 11:32 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Temp Gauge Quote: |
Originally Posted by caddydaddy If it's just a hair over the half way mark, don't worry about it. Mine and all other Sevilles will do that.
Congrats on the SLS! | I have yet to see mine move past 12:00, but I agree, nothing to worry about. |
05-28-06, 12:25 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1998 SLS - 160,000 mi | | Join Date: Dec 2004 Location: Petoskey, MI Age: 28 | | | Re: Temp Gauge i agree, nothing to worry about, the car will warn you with bells and whistles when it enters the danger zone. |
05-29-06, 07:04 PM
| | Cadillac Owners Member | | | | | Re: Temp Gauge Thanks....I feel much better know! I've enjoyed every minute of owning the car.  |
05-29-06, 10:17 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 94 Deville, 2000 STS, 2005 Escalade 2WD | | Join Date: Jan 2003 Location: Portland, ME Age: 28 | | | Re: Temp Gauge Quote: |
Originally Posted by Ranger I have yet to see mine move past 12:00, but I agree, nothing to worry about. | My STS' temp guage will move about an 1/8 inch past the 12:00 position sitting in hot weather. All other times, it never moves past 12. |
05-30-06, 12:04 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 01 Eldo ETC, 02 Deville | | Join Date: May 2004 Location: Salem, NJ Age: 56 | | | Re: Temp Gauge I'll chime in too to help calm your fears - I turned on the DIC display of coolant temperature back in the fall - the mid point on my gauge seems to cover temperatures from 190 to about 205 Degrees. One tick past it covers 205 to about 215. Two ticks, about halfway between the mid point aind the next gauge line, I've only seen once - idling with the AC on with ambient temp around 85 - the DIC read 222. I have never seen it hit then next gauge line. As soon as I started moving, it fell right down again to hover between 197 and 201.
No worries, mate.
"For a successful technology, reality must take precedence over public relations, for Nature cannot be fooled." - Richard P. Feynman  |
05-30-06, 12:47 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 1998 STS/2006 M6 GTO | | Join Date: Mar 2004 Location: Mahwah, NJ Age: 24 | | | Re: Temp Gauge Mine does that sometimes too. Usually when I get off the highway and get stopped at a light or somehtign right after. As soon as I start moving and air flows over the radiatior, it cools right back down. |
05-30-06, 08:59 PM
Originally Posted by JimHare I'll chime in too to help calm your fears - I turned on the DIC display of coolant temperature back in the fall - the mid point on my gauge seems to cover temperatures from 190 to about 205 Degrees. One tick past it covers 205 to about 215. Two ticks, about halfway between the mid point aind the next gauge line, I've only seen once - idling with the AC on with ambient temp around 85 - the DIC read 222. I have never seen it hit then next gauge line. As soon as I started moving, it fell right down again to hover between 197 and 201.
No worries, mate. | Thank Jim, thats good to know.  |
06-30-06, 12:17 PM
| | Cadillac Owners Fanatic | | | | | Re: Temp Gauge JimHare,
When you mention the "ticks," are you talking about the white marks??? The way I understand your post, when you say on tick, you mean the next white mark to the right of the midpoint, and two ticks is the 2nd white mark to the right of midpoint. Three marks past the midpoint, you start getting into the red zone. I'm only asking b/c I wanted to double check what you had posted about the temps. Yesterday, I had to drive from Phoenix to Tuscon and the temp outside was 107. I was driving 80mph with the a/c on and for a good 1/2 hour the temp gauge was 2 white marks past the midpoint. Based on what I read from your post, that equates to 222 or so. Am I correct??? |
06-30-06, 12:43 PM
|  | Cadillac Owners Fanatic Cadillac(s): 2000 Seville STS | | Join Date: Mar 2003 Location: Central Massachusetts | | | Re: Temp Gauge Jim,
Thanks for the info on temps. Can we all set our DIC to display temp or is this something common only to certain vehcles. I have a 2000 Seville STS and might like to set it up like you have it if that's a possibility.  |
06-30-06, 01:40 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 01 Eldo ETC, 02 Deville | | Join Date: May 2004 Location: Salem, NJ Age: 56 | | | Re: Temp Gauge Quote: |
My bad - I should have explained it clearer. I defined a "TICK" as one needle's width. So at the midpoint on the gauge, straight-up, 12 o'clock high, that's the exact center, and as I mentioned, seems to cover about 190 to 205 deg... when the needle moves one-needle's-width past the mid point, that's ONE tick : 205-212 or so..two is Two Ticks, etc. On my gauge, the next MARK on the gauge is about 3 to 4 needle's width's away - and I've never even seen it hit that first mark after 12 o'clock high...
Sorry for the confusion. Have attached pic for perhaps more enlightenment...
06-30-06, 01:42 PM
Originally Posted by Astronomer Jim,
Thanks for the info on temps. Can we all set our DIC to display temp or is this something common only to certain vehcles. I have a 2000 Seville STS and might like to set it up like you have it if that's a possibility.  | I am not sure if the process to display coolant temp on the DIC readout is the same from model to model. I did mine from a posting made here about 6-8 months ago, I don't recall who or exactly when. Do a search for "DIC COOLANT" or something similar, and you should find it. It involves changing the seed value for a number that is the key to what gets displayed in the DIC... not at all hard, just have to follow each step.
Hope this helps. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
