  Follow CadillacOwners on Twitter
Cadillac Forums: Engine Noise #2
Old 05-05-06, 01:29 PM
MacKiNBacK's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 2000 Seville STS
View MacKiNBacK's Photo Album
Casino Cash: $2705
Engine Noise #2
Lately ive been noticing an annoying noise under the hood. It coming from what I believe is the compressor. Noise starts when I have the heat on and stops when I turn it off. When looking under the hood its the pulley that has a triangle on it. Located on the bottom towards the front. Does anyone have any ideas on what to do? Is it something I may be able to do in my garage?
Thanks
MacK
  #2 (permalink)
Old 05-05-06, 02:17 PM
caddydaddy's Avatar
Cadillac(s): 2000 STS, 2005 Escalade 2WD
View caddydaddy's Photo Album
Casino Cash: $3497
Re: Engine Noise #2
That would be the A/C compressor. Run the car with the climate control set low, and press the A/C off button. If the noise goes away, then it's the compressor. Can you describe the noise better?
  #3 (permalink)
Old 05-05-06, 05:48 PM
View Ranger's Photo Album
Casino Cash: $27171
Re: Engine Noise #2
If the noise persists after turning off the A/C, then it is just the clutch.
  #4 (permalink)
Old 05-06-06, 12:21 AM
MacKiNBacK's Avatar
Casino Cash: $2705
Re: Engine Noise #2
Well I didnt have the ac on.. Had the temp set at 80 degrees.. Ill have to reply back with the noise.. Can't recall it right now.. Haven't turned on the heat in all week due to the noise. What I am sure of is that when the pulley with the triangle on it stops turning the noise stops.
MacK
  #5 (permalink)
Old 05-06-06, 01:45 AM
Cadillac(s): 94 sls
View 94greencaddysls's Photo Album
Casino Cash: $345
Re: Engine Noise #2
Sounds like your compressor is shot...If you have defog on the compressor would cycle on with heat also. It's a PITA to get at. There are always a couple compressor's floating around ebay for the northstar's.
  #6 (permalink)
Old 05-06-06, 08:49 AM
MacKiNBacK's Avatar
Casino Cash: $2705
Re: Engine Noise #2
I guess ill have to keep an eye out for one then. Also will make sure it's the compressor too.
Thanks
MacK
  #7 (permalink)
Old 05-06-06, 05:22 PM
Casino Cash: $27171
Re: Engine Noise #2
The pully itself turns all the time. The center (triangle) is the clutch. When the center is turning, the clutch is engaged and the compressor is running. If the noise follows the clutch engagement and thus the compressor, it sounds like the compressor is bad.
Tags: ,
engine, noise
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
