Originally Posted by sloggernobber I located the connector and first tried the multimeter on it. I kept getting around 15 ohms to start with but then the ohms just slowly kept dropping until after two or three minutes it had dropped to 2 ohms. I also tried the resistor bypass, cleared the codes and the C1711 still came back. Why does the ohms value drop down to 2 ohms? It drops at a steady rate, not like holding at 15 and then drops to 10. Any ideas? |
Here is the theory. Your Ohmeter can only measure the DC resistance of the coil of wire that makes up the solenoid valve in the strut. That coil of wire can be several hundred feet long and that much wire will have some measureable DC resistance. I measure 14.x Ohms on one of my '98 Seville strut coils with my Fluke meter and all that tells me is the coil has continuity (the coil winding is NOT an open circuit).
Be sure you are not touching the meter probes / connectors with BOTH of your hands; use at least one alligator clip to isolate your body from the measurement.
A resistance value that decays over time can indicate a temperature sensitive failed component. Your meter is supplying a small current to calculate the DC resistance and that small current is heating the coil of wire and causing the wire resistance to change over time. OR; the battery power supply in the meter is marginal. Not easy, huh?
I cannot explain why substituting the resistor did not prevent the code. There are too many possibilities. But I can tell you that resistor value worked for me on my '98 Seville as a test.
