Cadillac Forums: Code C1711 on 98 STS
  #16 (permalink)
Old 09-17-06, 11:13 PM
View sloggernobber's Photo Album
Casino Cash: $285
Re: Code C1711 on 98 STS
!!!!WHO'S YER DADDY!!! Its fixed!!! It was what Yves had described, a 1k resistor had died. I replaced it and bingo, yee hah doogy! I took a picture of the circuit board so I can identify the offender and post it. I will follow up on that this week when I am able to download the picture. And now for the 'Oscar' bit - I would like to thank Yves for pointing out the information and JimD for following up with the references. Nuff said, its time for an Englishman to hit Toronto and get drunk as a monkey!
  #17 (permalink)
Old 09-18-06, 12:50 PM
iametarq's Avatar
Cadillac(s): 1998 SLS - 160,000 mi
View iametarq's Photo Album
Casino Cash: $10786
Post the picture!!!
  #18 (permalink)
Old 09-19-06, 01:32 PM
Cadillac(s): '98 Seville STS
View yves's Photo Album
Casino Cash: $250
I was the same lucky as you slogger when I got fixed this error. To be honest, it was more luck then brain power.
Anyway, post the pictures....
@iametarq: Kind of funny our avatar. I had exaxtly the same fleed. 96 SebringJXi and a 98 STS.
About 4 weeks ago I sold the sebring.
  #19 (permalink)
Old 09-19-06, 09:10 PM
Casino Cash: $285
Sorry for the delay, I had to get a cable to download the images off my phone. So, hopefully the pictures will be of use to others. The images show the circuit board connector side down. The offending resistor is about 1mm square in size and is black. Under a magnifying glass you will see the numbers 102 on top of the resistor. This means (for what its worth) ten to the power of two which is 1,000 which is 1k ohms. It is on the top left side of the pcb under a row of three solder joints. On the images you will see a pointer right on the resistor. If you are going to repair this yourself, you will need to use a fine tip soldering iron so as not to wreck the component and damage the multi layer circuit board. If anyone needs further information please let me know.
  #20 (permalink)
Old 09-20-06, 05:24 PM
Casino Cash: $250
Thanks slogger for the detailed images. Exaxtly the same resistor was the problem on my board.
  #21 (permalink)
Old 12-15-06, 12:19 AM
cadillacjake's Avatar
Cadillac(s): 1998 Seville STS
View cadillacjake's Photo Album
Casino Cash: $250
Where is the CVRSS module located? I'm trying to pin down a C1711 code myself.
  #22 (permalink)
Old 12-24-06, 08:27 AM
mcsteve's Avatar
Cadillac(s): 98 STS
View mcsteve's Photo Album
Casino Cash: $520
Thumbs up Re: Code C1711 on 98 STS
The module on my '98 STS is located behind the rear seat. There are 2 modules behind the seat and the CVRSS is the top one. You access it by removing the liner in the trunk.
I've been getting this error and originally thought it was the damper but when I took it to the dealership to verify, they said I needed a new module. They wanted $2,200 + labour to replace it. Needless to say I pulled back out of the dealership and decided to see if anyone on the forum here had found a repair for this.
This thread has saved me about $2,197.05. The resistor cost me $2.95 (I had to buy a pack of 5) and the process took about an hour to complete. I also needed a work area magnifier as the component is very hard to see and the connection is very difficult to make. I would suggest anyone doing this also spend a few cents for some rubber shrink wrap. Once you solder the risistor in place, it is very close to other connections and you will want to ensure that it does not make unwanted contact by wrapping it after it is installed.
Thank you to sloggernobber, JimD and yves for all of the details and pics. Great work.
  #23 (permalink)
Old 12-24-06, 11:25 AM
dp102288's Avatar
Cadillac(s): 1995 Pearl White Diamond Cadillac Eldorado ESC
View dp102288's Photo Album
Casino Cash: $250
^^ Don't you just love this board! $2,197.05 vs $2.95 is a great example!
  #24 (permalink)
Old 12-24-06, 11:58 AM
Cadillac(s): '98 STS
View JimD's Photo Album
Casino Cash: $18558
Glad to help. Spend some of the savings on new tools!!
  #25 (permalink)
Old 07-05-09, 03:34 PM
Cadillac(s): Cadillac
View maciek123's Photo Album
Casino Cash: $1470
Hi
In my case problem with 84/C1711 it was also resistor in CVRSS module. I cant imagine what potential costs I could have without this post you made.
And in addition to this information my car sometimes was reporting error 84 together with 113 and sometimes 113 only.
Thanks All!!!!
Maciek
  #26 (permalink)
Old 08-10-09, 08:59 PM
View Justspin's Photo Album
Casino Cash: $300
Awesome!!! Just went through and checked why my 98 STS was throwing this code and traced it to the bad resistor in the module. Quick trip to Radioshack $1.00 in gas, $1.06 for 5 Resistors, $.01 roughly for solder and wire I had laying around. Less than an hour total of my time. Low and behold after clearing codes the damn thing is fixed!!!! You guys rock! Thanks for the info and pictures. I thought I was gonna need million dollar struts and I spent roughly $2.07. Time to hit the interstate and see how fast she goes now, LoL. Just kidding!
Tags: , ,
c1711, code, sts
