Refregerant Again?!?!?!
Results 1 to 13 of 13
Cadillac Seville / Cadillac Eldorado Forum Discussion, Refregerant Again?!?!?! in Past Cadillac Vehicle Discussion; i own a cadillac eldorado 1997 and I once submitted a thread needing help with adding freon to my car.. ...
    da17 is offline Cadillac Owners Member
    Oct 2005
    56
    i own a cadillac eldorado 1997 and I once submitted a thread needing help with adding freon to my car.. i added it and everything worked smoothly for a day, now when i turn my AC on no cold air comes out and when i check the pressure gauge it goes up to around 40psi then goes down again and continuosly does that? why is that?? what does it mean?
    69
    82,163
    Re: Refregerant Again?!?!?!
    What are the low & high side readings? Do you have the low refrigerant message?
    Oct 2005
    56
    Ranger..
    let me elaborate a little more on the situation..
    the outside temperature is 50F and the lowest it goes in the car is 60F maybe thats why its not working.. i added more than enough Refregerant.. it reads around 60psi.. so do u think its normal because the outside temperature is cold so it cant make it any colder?
    69
    82,163
    That is a good question. I am not sure if the system can bring the temp below 60 as that is the lowest you can request. I do know you can put too much refrigerant in. I also know that those single low side guages that come with the refill cans or are purchased seperately (if that is what you were using) are useless.
    Oct 2005
    56
    What happens if i put too much refregerant in it?
    69
    82,163
    EXCESSIVE HEAD PRESSURE:
    This is mainly caused by overcharging the system which results in flooding the condenser. This in turn reduces the effective condensing area and results in high side pressures that can place excessive loads on the compressor. Other causes can be faulty condenser fans and debris lodged in condenser fins. These will result in reduced airflows which will cause condensing pressures to rise beyond acceptable thresholds.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Do you have a gauge set or just the low side gauge?
    A low side gauge is not enough to work on your AC. If you want to work on it get a gauge set. Then you can tell us if you added enough refrigerant. It sounds like it is still low. Use the low side gauge only AT YOUR OWN RISK.
    iametarq's Avatar
    iametarq is offline Cadillac Owners Connoisseur
    Automobile(s): 98 Deville, '15 Ford Fusion Hybrid Titanium, '12 Ford Escape
    Dec 2004
    Petoskey, MI
    36
    3,294
    i have seen adaptors to use the lowside guage set on the high side, since the high side "plug" is bigger than the lowside "plug" but I have not used any of them before.
    69
    82,163
    Quote Originally Posted by iametarq
    Wouldn't that be kind of like plugging a 110v motor into a 220v outlet? In any case, I think you need to watch both guages at the same time. Like Zonie77 said, if your gonna do your own A/C work, you really need a good set of guages.
    Oct 2005
    56
    i dont understand.. isnt it just plug and go.. i mean all i need to do is connect the low side to the freon and fill till the gauge reads full.. whats more to it than that??? why need more gauges and whatever?
    69
    82,163
    No, it is not like filling coolant. There is a relationship between the low side and high side pressures.
    http://www.autoacrepairs.com/gauge_r..._diagnosis.htm
    Sep 2003
    Arizona
    3,531
    Quote Originally Posted by da17
    NO, it is not plug and go. If it was your AC would be working now. Ranger sent you a good link. AC is not real hard but you have to know what you are doing.
    69
    82,163
    Here is a better example.
    http://autoacrepairs.com/temperature.htm
  16. Remove Advertisements
