What Do These Codes Mean???
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, What Do These Codes Mean??? in Past Cadillac Vehicle Discussion; I got 2 codes i have no idea what they mean PCM P0603 - Control Module Long Term Memory Reset ...
    da17 is offline Cadillac Owners Member
    Oct 2005
    56
    and
    PZM B2472 : Low Beam Fault
    what do they mean???
    68
    82,063
    Re: What Do These Codes Mean???
    P0603 may just be from pulling battery power. Done that lately?
    B2472 is obviously a headlight problem.
    If you have no problems and they are history, clear 'em and ignore them unless they come back.
    iametarq's Avatar
    iametarq is offline Cadillac Owners Connoisseur
    Automobile(s): 98 Deville, '15 Ford Fusion Hybrid Titanium, '12 Ford Escape
    Dec 2004
    Petoskey, MI
    35
    3,294
    as ranger said it's a headlight problem. are your head lights working when you turn the lights on?
    the 2nd one i'm not sure on.
    Oct 2005
    56
    the headlight is a history and they are working fine.. but i didnt touch the battery!! what does the P0603 mean exactly? bad battery? bad cords/cables?
    FrankT's Avatar
    FrankT is offline Cadillac Owners Enthusiast
    Automobile(s): 99 STS
    Mar 2004
    Michigan
    61
    700
    CoolRe: What Do These Codes Mean???
    Quote Originally Posted by da17
    P0603 is An intermittent loss of power or ground to the PCM and it caused a PCM reset. Check all power and grounds to the PCM if they check OK the PCM could be going bad. At this time just clear codes, check your battery connections and see it the DTC returns, do not replace the PCM yet.
    Frank
    Oct 2005
    56
    Where/what is the PCM? where can i find it?
    68
    82,063
    PCM (Powertrain Control Module) is under the air filter intake box for cooling.
  10. Remove Advertisements
