Results 1 to 6 of 6
Thread: Could it be the starter? 95 SLS
    Sep 2005
    36
    37
    I have a 95 SLS and I think I might have a starter problem. My battery is brand new as of a month ago. I drove around this evening, no problem. The car sat in the driveway for a couple hours and just a little while ago I drove about 1 mile to my church. After being inside for about 15 minutes I returned to the car and it would not crank. The lights, radio, wipers, all work fine but when I turn the key to start the engine all I hear is a CLICK! (and yes it was in park, foot on brake, etc.)
    Any thoughts?
    Starter easy to change?
    Thanks,
    Phil
    69
    82,262
    Re: Could it be the starter? 95 SLS
    Check the battery cables for corrrosion and tight connections. If that is ok, have the battery checked.
    Sep 2005
    36
    37
    Quote Originally Posted by Ranger
    Even though the lights and radio work fine and the batt is new? Could a loose connection cause it not to crank but other things work? (b/c I did check it, it was a little loose, but i tightened it.)
    Thanks for your help.
    Phil
  5. #4
    69
    82,262
    The battery can be fine to run low load items like lights and radio but, put a heavy load on it like a starter and it falls flat on it's face. Don't assume just because it is "new". I have had them fail in 6 months. I have even had them bad right off the self. You have all the symptoms of a dead cell. Have it load tested or swap (not jump start) it with a known good battery to check it.
  6. #5
    Sep 2005
    36
    37
    In accordance with your advice I went back and checked the battery. Turns out the connector was loose to the positive terminal. (side posts, ugggg),, I tightened it and it started right up.
    Thanks for all your help. I am going to relocate the connections to the top posts on Monday - I really dislike those side connectors!
    Phil
  7. #6
    69
    82,262
    That was easy
  • You may not post replies
