Erratic speedo and no cruise control
Results 1 to 6 of 6
Cadillac Seville / Cadillac Eldorado Forum Discussion, Erratic speedo and no cruise control in Past Cadillac Vehicle Discussion; ...
    Andyfink is offline Cadillac Owners Member
    Automobile(s): UK 98 STS
    May 2005
    6
    Hi everyone,
    I have been reading the forum for some time now and wonder if anyone can help me out - or rather help the UK garage where my STS 98 Cadillac is sitting at the moment!
    I'll try to keep a long story short - I live in the UK and have a right hand drive cadillac which had an auto transmission problem...No Reverse Gear!!!!!
    I paid a "recommended" garage £3700 !!!!!! to sort it out - it's now on it's 4th visit because they are struggling to repair it. Basically they have now fitted the auto gearbox 4 times and everything seems fine in the gearbox except when driving at 70mph the speedo is erratic (displays any number between 70 - 105 in about 1 second!) . Also... the cruise control does not work at any speed!
    They have now replaced the electronic speed device in an attempt to fix the problem but this has not cured the faults.
    Have any of you come across this problem before??
    best wishes
    Andy
    Rock's Avatar
    Rock is offline Cadillac Owners Fanatic
    Sep 2005
    NH
    63
    131
    Re: Erratic speedo and no cruise control
    I had a similar problem with my Speedo. Replaced the 20-dollar Speed Sensor that mounts on top of the Transmission tail-housing (accessed through the passenger-side wheel well) and everything was fine.
    Good Luck.
    May 2005
    6
    Hi Rock,
    Thanks for your reply - I'm not sure whether this is the unit the garage have replaced already...hopefully not else I may still have the problem!
    I'll have a chat with them on Monday and see what they say.
    best wishes
    Andy
    69
    82,180
    The sensor Rock is talking about is the VSS (Vehicle Speed Sensor). The input speed sensor however, is a $20 sensor, $2000 deep in the trans. That said, I am not sure which would cause your problem but, I would venture to guess that it is one of them. A FSM would be invaluable.
    danbuc's Avatar
    danbuc is offline Cadillac Owners Connoisseur
    Automobile(s): '87 Jeep, '10 Thruxton, '00 Duc 748, '01 748R (853cc)
    Mar 2004
    Mahwah, NJ
    31
    3,703
    Check for codes to see what comes up. Just as an example, P0502/3 are VSS codes. I had both of these, and replaced my VSS a few days ago, with similar symtoms (my speedo would sometimes just drop all the way to 0 though).
    Beefmalone is offline Cadillac Owners Member
    Feb 2006
    Jackson, MS
    58
    When my vss went out it did the same thing you are describing...speedo was erratic and no cruise.
  9. Remove Advertisements
