Cadillac Forums: Is it worth repairing a bad head gasket on a 79 Eldo?
Old 03-17-06, 11:50 PM
GM-MAN's Avatar
View GM-MAN's Photo Album
Casino Cash: $250
Well, my other pride and joy is leaking coolant (white smoke from sides of engine, under sparkplugs and starts to fill the interior) which I at first thought was oil from the valve covers.
I changed the valve cover gaskets but immediately found that it wasn't it. It looks like the head gasket.
Car does not overheat and runs fine but coolant is low from the overflow bottle.
It has a 350 Olds F/I gas engine. The body, frame and interior are almost perfect still.
Is it worth repairing the head gasket, replacing the engine or just sell it now?
Thanks for your advice.
  #2 (permalink)
Old 03-17-06, 11:58 PM
View Ranger's Photo Album
Casino Cash: $24241
Re: Is it worth repairing a bad head gasket on a 79 Eldo?
Sell or repair is a choice only you can make. Why replace an engine. I am pretty sure you can R & R the head gaskets on that engine without removal. That makes it much easier to DIY.
  #3 (permalink)
Old 03-18-06, 12:10 AM
View Beefmalone's Photo Album
Casino Cash: $250
Head gaskets on an olds aren't too hard to do. Is there water in the oil (chocolaty)?
  #4 (permalink)
Old 03-18-06, 12:19 AM
GM-MAN's Avatar
Casino Cash: $250
Hmmm, I checked the oil level and looks brown as usual but I'm not sure what you mean by chocolately.
I looks like engine oil is all. Same as in my LeSabre or Escort.
Or are you asking me if there is oil in the coolant?
  #5 (permalink)
Old 03-18-06, 12:21 AM
GM-MAN's Avatar
Casino Cash: $250
I called my mechanic and he's yet to get back to me with a quote. I don't really have the confidence to do the head gaskets myself. It doesn't look like a straight-forward repair, albeit time consuming.
  #6 (permalink)
Old 03-18-06, 02:06 AM
Casino Cash: $250
no I mean coolant in the oil. it will make it turn a chocolate brown color. white smoke in the interior can be a sign of your heater core going bad. check into it before you spend a bunch of money.
  #7 (permalink)
Old 03-18-06, 03:04 AM
Cadillac(s): 1997 Eldorado
View Zorb750's Photo Album
Casino Cash: $1180
Does it smolder or billow? If it billows it's steam, if it looks smoldering it's oil burning. You can smell it, coolant/steam has little smell.
  #8 (permalink)
Old 03-18-06, 11:38 AM
GM-MAN's Avatar
Casino Cash: $250
Will, it smolders actually. Looks like the smoke coming from the sides of the engine are entering the interior. Of course, it's strange since I have the hood up. The smoke should exit, not enter the heater vents.
Still, the oil looks fine and the collant is nice and green, though low on the overflow right now. But the car has sat since November for the winter.
I wish I could get a mechanic to look at it on my driveway is all.
I have a buyer coming buy today to look at the car but I'm trying to stall this. I DO NOT WANT TO SELL IT!
  #9 (permalink)
Old 03-18-06, 11:53 AM
Patrick7997's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 1997 ETC (sold), 2004 Escalade, 2007 HD Road King Classic
View Patrick7997's Photo Album
Casino Cash: $1145
Love your car... I had a 79 with the same engine.... not that easy to find.
I had a blown head gasket.... the radiator fluid was turning brown with oil, and the oil level was RISING with the added radiator fluid, and turning brownish.... You will know, if that's what you really have. I didn't have any steaming....
The car actually ran halfway decent, though...
Beefmalone & Zorb have some good thoughts.... you owe it to yourself to find out what's really wrong FIRST, and then plan a course of action....
I was actually all set to put a rebuilt engine & trans in the car, I liked it that much, but my frame rails were really gone... so it was not a candidate for restoration, sadly... too much salt up here... oh well.
  #10 (permalink)
Old 03-18-06, 12:01 PM
GM-MAN's Avatar
Casino Cash: $250
It's true, I adore this car. I've yet to own it a year so I'm loathe to part with it, especially since it's my favorite model cadillac and the best year for the engine. Yes, very hard to find.
Regardless, the coolant in mine is still very much green and full on the rad. The oil looks like clean oil. Since I've yet to even put 1000KM on the engine since I bought it and did an oil change as soon as it was mine, I'm not surprised to oil looks so clean.
Salt here is also an issue but the body and frame are both excellent and strong. The interior is immaculate.
The point is, if the mechanical was mint but the body and frame only so-so, then I'd sell it. Much more expensive to fix the body and frame rather than mechanical.
Is it possible I may have misdiagnosed this issue? What could it be then?
I start the engine and everything runs fine, except the bubbling of what looks to be coolant right under the sparkplugs. It smokes on either side and after anoth minute, the smoke begins to enter the interior.
  #11 (permalink)
Old 03-18-06, 12:52 PM
Casino Cash: $24241
Bubbling under the spark plugs sure sounds like a head gasket. I can't think of anything else in that location that could leak coolant I am sad to say.
  #12 (permalink)
Old 03-18-06, 02:01 PM
GM-MAN's Avatar
Casino Cash: $250
Now after double checking it, I found out it really is oil, not coolant.
Though the oil is still full and my coolant is fine, it explains why the car does not overheat.
Could it still be the head gasket?
  #13 (permalink)
Old 03-18-06, 02:13 PM
Cadillac(s): 94 ETC,97 STS
View zonie77's Photo Album
Casino Cash: $7829
It could be a head gasket. There are coolant and oil passages between the heads and block. Depending on where it leaks it will give different symptoms. Not all head gasket leaks act the same.
  #14 (permalink)
Old 03-18-06, 02:17 PM
Casino Cash: $7829
You have to consider the condition of the car and what it will actually cost to fix. You didn't get an estimate yet.
Another idea is having a school shop class fix it. You should call all the instructors around and see what the chances are of doing this.
Or build up the confidence. Head gaskets aren't that hard.
  #15 (permalink)
Old 03-18-06, 03:28 PM
GM-MAN's Avatar
Casino Cash: $250
Not that hard? If that's the case I have no problem trying it myself. I don;t think I have anything to lose. It's just that I thought I would have to re-align a few things.
I'm just not sure. I've never opened up an engine before. Of course, it does give me the opportunity to actually see for myself and clean it out while I have it open. Maybe even change the timing belt while I'm at it?
*sigh* But I do need to get an estimate. I just figured head gaskets were around $2000 or so.
EDIT: BTW, you guys have been extremely helpful so far. I may wait for the spring weather and spend a weekend opening it up.
Tags: , , , , ,
bad, eldo, gasket, head, repairing, worth
