1997 ELorado Radiator Fan Speed
Results 1 to 2 of 2
Cadillac Seville / Cadillac Eldorado Forum Discussion, 1997 ELorado Radiator Fan Speed in Past Cadillac Vehicle Discussion; My engine temperature keeps going up and down. I mean from normal to hot. When the fan final go faster ...
    joedana0502 is offline Cadillac Owners Member
    Jun 2005
    8
    My engine temperature keeps going up and down. I mean from normal to hot. When the fan final go faster it will cool down the engine down. I have seen the fan run at different speeds. My question is does the fan have more than 1 speed. If so could the thermostat that controls the speed be bad. If so could it be the plug at the top of the radiator with 2 wires coming out of it. Thanks for your help.
    68
    82,048
    Re: 1997 ELorado Radiator Fan Speed
    The fan has two speeds. It comes on low at 224 degrees and high at 230.
