99 STS trans fluid
Results 1 to 3 of 3
Cadillac Seville / Cadillac Eldorado Forum Discussion, 99 STS trans fluid in Past Cadillac Vehicle Discussion; which should i use, ours is a little low and i want to top it up with the correct fluid, ...
    crimson_pearl is offline Cadillac Owners Member
    Sep 2005
    11
    99 STS trans fluid
    which should i use, ours is a little low and i want to top it up with the correct fluid, i presume its not what my BMW 3 series uses?
    69
    82,269
    Re: 99 STS trans fluid
    Dexron III.
    I think GM now has a Dexron IIII or V (can't remember which) but it is compatable.
    Zorb750 is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Eldorado, 2003 Audi RS6
    Apr 2005
    Oakland County, MI
    33
    1,320
    There's a Dex 4, but it's only at dealers as far as I know, and it's also expensive. They claim it's one of those "Lifetime" fluids. If your BMW 3 series has a GM Hydramatic trans, you can use the BMW fluid. If it's the ZF, you can't. I mean you could flush out all the Dexron fluid in your Cadillac and convert to Esso LT71141, but at $20-30/L... I wouldn't. Just so you know, do not EVER put GM Dexron in a BMW that doesn't use it. There's a TSB for the E38 7 series regarding transmission malfunction eventually leading to failure resulting from the installation of GM trans fluid, even as a top off. It's somehow not compatible with BMW's ZF transmission clutch material.
