Potential STS buyer with questions
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Cadillac Seville / Cadillac Eldorado Forum Discussion, Potential STS buyer with questions in Past Cadillac Vehicle Discussion; Hello all. I'm looking at a 1999 STS, 110K miles, 2 owner, and the second owner has all maintenance records ...
    CoreZman's Avatar
    CoreZman is offline Cadillac Owners Member
    Mar 2006
    7
    Hello all. I'm looking at a 1999 STS, 110K miles, 2 owner, and the second owner has all maintenance records since 16K miles. One of the things the seller notes is that the car consumes about a quart of oil every 3K miles or so and has since he bought it at 16K miles. Is this normal? The driver's side seat heater does not work? Is this fixable? How expensive is it to replace the windshield? It has a bb sized mark in the lower left corner that has been there for two years and hasn't grown.
    I have yet to personally inspect the car and hope to do so in the next day or two. What should I look for that will tell me to stay away? I know about the trunk gasket issue from reading here, and that if the coolant system hasn't been maintained then the engine could be in trouble. Any other biggies or suggestions? Thanks!
    FredMaxwell Guest
    Re: Potential STS buyer with questions
    I've heard from alot of people that it is normal for the Northy to use some oil,
    I've seen the seat heaters on ebay for $300 per brand new set,
    The bb sized chip - don't worry about it.
    You can have it filled if that would make you feel better.
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    51
    2,817
    The N* uses oil. It is not only normal, it is epidemic. All N* use oil. Most use a quart every 2,000 miles or so. Oil is cheap, do not worry about it. I just replaced my windshield about a month ago. Cost was $364.00. But I had a three foot crack across the bottom. A small chip, not in the line of sight, I wouldn't change it. Run diagnostics on the car when you inspect it. It is fast and easy. Test drive the car first. Get the car warmed up, and drive at different speeds. If at all possible, drive between the speeds of 60 and 75. Some Seville's have an annoying vibration between these speeds. Anyway, back to the codes. After driving the car, shut it off (or leave it running), with the key in the "on" position, hold down the on/off switch, and the up button, that is to the right of the steering wheel. The dash will go black, and then at the bottom, a message pops up. Hit the on/off button twice, and write down the codes that come up (hopefully there aren'y any). Check back with the codes here, and there are plenty of folks to help out. Hope everything works out for you, these cars rock.
    Don
    CoreZman's Avatar
    Mar 2006
    7
    Quote Originally Posted by Dadillac
    Don
    good stuff. thank you very much.
    69
    82,287
    The BB hole in the windshield came be fixed to almost indetectable. Most insurance companies will pay for it to avoid replacing the windshield. If it is not right in your field of vision, it is a good fix. It will appear as no more than a water spot.
    This should aleviate your concerns about oil usage.
    http://www.cadillacforums.com/cadillac-tech.html#noil
    CoreZman's Avatar
    Mar 2006
    7
    Thanks Ranger. I did finally find my way to the tech section to read that article. The more I read the more I'm getting excited about this car.
    edit: three more questions for now. The battery in the car is original, so I anticipate replacing it (if I buy the car). Does the STS require any special battery, about how much should I expect to spend, and how hard is it to replace (I haven't seen the car yet)?
    69
    82,287
    I think it may require a "special" battery as it is located under the back seat so it has vent tubes to vent the gasses to the outside. I haven't had to replace one yet so I am unsure of prices. My guess would be worst case about $125 from a dealer. It does not look hard to do.
    CoreZman's Avatar
    Mar 2006
    7
    Ok I took the car for a drive today and it went well. The car started right up, idled silently, accelerated smoothly, and when I went WOT there was no hesitation, no strange noise (just the beautiful roar of the engine), and no smoke. The only thing I thought was a bit strange was that I expected the steering to be less stiff. I currently drive a 1972 Datsun 240Z that doesn't even have power steering and this car seemed stiff to steer. It got very stiff in the parking lot as I turned into the parking space. The seller says it's always been this way. Does that sound right?
    gcl2 is offline Cadillac Owners Member
    Automobile(s): 1999 sts
    Sep 2005
    12
    Just purchased my Battery for my 99 sts from Dealer..$102.00..
    Easy change out as well.
    George
    rbrandon's Avatar
    rbrandon is offline Cadillac Owners Member
    Automobile(s): 99 STS
    Jul 2004
    Brooklyn, NY
    35
    71
    Quote Originally Posted by CoreZman
    the steering should stiffen up at speed, but not while parking or anything. check the PS pump.
    CoreZman's Avatar
    Mar 2006
    7
    Quote Originally Posted by rbrandon
    Will do.
    Another question:
    The seller says that at around 60K miles (~50K miles ago) he flushed and filled the coolant system with 50/50 dex/distilled, but did not use any tablets. Should this cause concern? Should I retreat the system if I buy the car?
    I<3me is offline Cadillac Owners Member
    Mar 2006
    11
    Good post Dadillac! Care to post in my thread about 98 Seville? would appreciate your 15 cents and love to hear what you have to say Daddy-O?
    JimHare's Avatar
    JimHare is offline Cadillac Owners Connoisseur
    Automobile(s): 01 Eldo ETC, 02 Deville SOLD!
    May 2004
    Salem, NJ
    64
    1,815
    The N* uses oil. It is not only normal, it is epidemic. All N* use oil. Most use a quart every 2,000 miles or so. Don
    That's not necessarily true, across the board. I think the 2000+ Northstar oil usage is somewhat diminished from the 90s models.
    My 01 Eldo hardly used a drop between 56K when I bought it and 65K when I just changed it. I put my used oil in the containers, and my drain tub filled 6 quarts bottles and a bit of a 7th. I don't remember EVER adding any, and I checked it every week. The level never when out of the hash marks on the dipstick.
    It's also a documented fact that the WOT treatment will cut down on oil consumption, if it becomes a worrisome problem.
  16. #14
    69
    82,287
    Will do.
    Another question:
    It is of no concern. The tabs are simply to prevent niusance leaks. Add them when you get a chance or at the next coolant change.
  17. #15
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    JimHare, I cannot speak for all N*, but my '02 goes through it's share of oil. I haven't met a N* I didn't like. I also haven't met a N* that didn't use oil.
    Don
  18. Remove Advertisements
