Cadillac Woes! Can't Figure it out!
Results 1 to 12 of 12
Cadillac Seville / Cadillac Eldorado Forum Discussion, Cadillac Woes! Can't Figure it out! in Past Cadillac Vehicle Discussion; Hey Everyone! I'm new the forum, and love it. Almost all the problems I have ever had with my car ...
    cadillac85 is offline Cadillac Owners Member
    Mar 2006
    4
    Hey Everyone!
    I'm new the forum, and love it. Almost all the problems I have ever had with my car has been already covered here. Most recently I had a problem with the car surging at stops and got that fixed on advice by doing as Ranger did, and changing the spark plug wires.
    Well a few nights ago an entirely different problem hit my baby (1998 Cadillac STS). The car was driving incredible as usual and I was on the acceleration ramp getting onto the highway, I gave the car a little more gas to speed up and get in before the traffic and the car just shut off. I was able to get it to the shoulder with the speed it was going at. At the shoulder I tried to start it up again, and it started fine. It idled perfect, so I put it in to gear and thought it would be fine, I was wrong as soon as I gave it gas the rmps started to go crazy up and down, the car started going then stopped almost like it was stutering, as if something was letting it accelerate then taking all power away, then trying again. I shut it off and tried it again, but left it in park this time, and the exact same thing happened when I gave it gas. If I put my foot all the way down on the gas, it will just rev the rpm's all the way up then drop like a rock, go all the way up then drop like a rock, all the while the car is shaking like crazy.
    If any of you have ever experienced anything like this before, or have any ideas on what it could be please help!!!
    Even my mechanic doesnt seem to know what exactly is wrong with the car.
    Thanks in Advance!!!
    68
    81,917
    Re: Cadillac Woes! Can't Figure it out!
    Start with the basics and pull the codes.
    Pjs's Avatar
    Pjs
    Pjs is offline Cadillac Owners Fanatic
    Mar 2004
    Nashville, TN
    367
    if the codes don't tell you anything, check your fuel pressure
    FredMaxwell Guest
    My ex wifes car did something similar and believe it or not it was the charging system
    Zorb750 is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Eldorado, 2003 Audi RS6
    Apr 2005
    Oakland County, MI
    33
    1,320
    If no codes... I would check in order: O2 Sensor, MAF, connections at ignition module (coil cluster), coils themselves, TPS, FPR.
    blackfrontier's Avatar
    blackfrontier is offline Cadillac Owners Fanatic
    Jan 2006
    105
    Stalling out at highway speeds could be a faulty Fuel Pressure Regulator. Check to see if fuel pressure is dropping below 30PSI. Replace if needed as well as the fuel filter.
    Mar 2006
    4
    Thanks everyone for your help, I gave it to my mechanic and even he seems to be dumbfounded by this, he originally thought it was something to do with the fuel line, but now says it is not the fuel line or filter, he now believes it is the ignition module. I had the Fuel Pressure Regulator changed a few months ago, because of another problem with the car surging.
    I checked the codes and the only one that comes up as current is RSS C1762 (Left Rear Position Sensor - Input False), but I doubt that has anything to do with my problem. Do you guys think it's possible for it to be the ignition module itself? I'll have to tell my mechanic to check the charging system. But thanks again for everything. I really dont want him to change the ignition module and have it be something else especially with the price of these parts. Any other suggestions?
    iametarq's Avatar
    iametarq is offline Cadillac Owners Connoisseur
    Automobile(s): 98 Deville, '15 Ford Fusion Hybrid Titanium, '12 Ford Escape
    Dec 2004
    Petoskey, MI
    35
    3,294
    I vote for the Ignition module. I had an old cadillac that would shut off randomly, and i think the part we had replaced was the ignition module. but i'm no expert.
    Apr 2005
    Oakland County, MI
    33
    1,320
    On a 1997 SLS the O2 sensor reduced its idle to a shaky mess that stalled if you let off the gas. There was some kind of crap in the connector for it and it was shorting with some sort of corrosion.
    Mar 2006
    4
    I just talked to my mechanic there is a little bit of a hold up getting a hold of an ignition module, but hopefully we are able to resolve the problem, its a good think i've built a good relationship with the mechanic. So I will only have to pay for the part, he said it only take like 15 minutes to connect. Makes me wonder why GM wanted to charge me over $1000 dollars for this job.
    Anyway I will post tommorow to say if it solved the problem. Thanks again.
    Apr 2005
    Oakland County, MI
    33
    1,320
    Yeah changing that is a walk in the park. It took less than 10 minutes to get it off my car when I changed the HVAC fan.
    Mar 2006
    4
    Well my mechanic got the part (ignition module) installed today, I'm happy to say everything is working great again. Thanks everyone for your help. And hope if anyone else experiences the same problem, they have an idea of what to do now. I'm just really thrilled now that my caddy is back, and life is back to normal.
  15. Remove Advertisements
