Ride Level Sensor
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, Ride Level Sensor in Past Cadillac Vehicle Discussion; Morning Gents, Is there a way to check a ride level sensor to see if it's working right? I had ...
    Guy,mn.usa is offline Cadillac Owners Fanatic
    Sep 2005
    136
    ExclamationRide Level Sensor
    Morning Gents,
    Is there a way to check a ride level sensor to see if it's working right? I had the back end of my 98 sts come way up in the rear and would not come down until I unplugged the drivers rear sensor...
    Please HELP!
    At 140.00 a sensor I want to replace the bad one not all 4.
    Thanks,
    Guy
    Aaron J Williams's Avatar
    Aaron J Williams is offline Cadillac Owners Member
    Automobile(s): 61 ragtop,2 67 eldos,68 ragtop,68CDV,89SDV,90 fleet,93 ETC
    Apr 2005
    Luck Wisconsin
    50
    75
    Re: Ride Level Sensor
    Does yours have road sensing suspension? If so,it would have 2 height sensors in the rear instead of one.
    Sep 2005
    136
    Yes it has 2 sensors in the back. I disabled the drivers side now the rear end does not pump up to max height. So with that I think I unplugged the bad sensor. Do you know how to check these to find out if the sensor is shot?
  5. #4
    68
    81,745
    I think you are looking at the wrong sensors. Get under the car. There is a lever attached from the switch to the body. Not sure which side. That is the control for the ELC. Sounds like you are pumping up the shocks but not releasing the air when needed. There is an exhaust valve on the ELC compressor. That may be your problem.
  6. #5
    Sep 2005
    136
    Morning Ranger.
    There are 2 level sensors attached to the inside of the wheel well, then a rod that attaches to the "a" arm. What your saying makes sence. The reason I say that is because now with one of the level sensors(driver side) today again the car pumped up the back end and stayed there! Help me fix this thing. If I'm understanding this correctly there is a sensor that tells the compressor to exhaust? Thank you for your help so far as I have not ran out and bought a level sensor at 140.00 a pop at cost!
    Thank you.
  7. #6
    68
    81,745
    A service manual would be invaluable at this point. If you don't have one, do a search for ELC exhaust valve or something similar.
  8. #7
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Check your codes.
  9. Remove Advertisements
