Dashboard uninstall, how to do it?
Results 1 to 2 of 2
Cadillac Seville / Cadillac Eldorado Forum Discussion, Dashboard uninstall, how to do it? in Past Cadillac Vehicle Discussion; I have a 1997 Eldorado, and one of the lights on the dash burnt out. Does anyone have the link ...
    Bryan24v is offline Cadillac Owners Member
    Jan 2006
    1
    I have a 1997 Eldorado, and one of the lights on the dash burnt out. Does anyone have the link or the instructions to remove everything? Thanks alot for your help, I think having that information will make everything go smoother and I wont break any parts.
    bubbarivi is offline Cadillac Owners Member
    May 2005
    Las Vegas
    12
    Re: Dashboard uninstall, how to do it?
    you can use a chilton's manual, or remove the top grill and removing the two sensors by turning counter clockwise. There are three 7mm bolts across the opening. there are four more bolts behind the dash vents. use a thin blade screwdriver or better a flat steel guage(ruler) to release the tab and then gently pull from the center. once all 7 bolts are out the dash will lift up and then pull out. disconnect the 3 harnesses at the back of the cluster and remove the 4 screws holding it in and then lift up and out. use a t-15 torx to remove the screws on the face and then you can disassemble the cluster.
