How to get codes?
Results 1 to 9 of 9
Cadillac Seville / Cadillac Eldorado Forum Discussion, How to get codes? in Past Cadillac Vehicle Discussion; Just joined the other day and doing alot of reading. Just trying to learn about my '98 STS. BTW, I ...
    GodsGreenCaddy is offline Cadillac Owners Member
    Feb 2006
    How to get codes?
    Just joined the other day and doing alot of reading. Just trying to learn about my '98 STS. BTW, I am a first time Caddy owner . I see a few threads on cars throwing codes, but I can not locate where everyone is getting the codes from. I checked my dash info area and not really coming up with anything. This could be good though if I do not see anything. I started checking into the owners manual, but that thing is over 300 pages and I do not like to read.... LOL!! I also ordered the service manual and will have that Friday afternoon. For the most part, I have found alot of info I need to know about this car. Look forward to future posting. Any help will be appreciated.
    Thanks
    gary88's Avatar
    gary88 is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2007 E92 BMW 335i
    Nov 2005
    Chicago, IL
    28
    10,760
    Re: How to get codes?
    To the left of your gauges where you have the 3 buttons (Info, info reset, and on/off), hold down info ^ and the on/off button together, after a few seconds your dash will light up, and it will say "All Codes?" Press the on/off button to indicate yes, and your car will run through all the codes. At the end it will say "All clear codes?" Press on/off, and all old codes will be cleared out. You can go here to find out what your codes mean http://www.obdii.com/codes.asp
    By the way, welcome to the forums
    Feb 2006
    Thanks for the quick reply. I will check that out tomorrow. I see lots a questions and alot of headaches in my future though. Not with problems, but on what I want to do with the car.
    69
    82,163
    See post #5 by JimD. It is a little more detailed.
    http://www.cadillacforums.com/forums...ighlight=Codes
    youngrudy's Avatar
    youngrudy is offline Cadillac Owners Member
    Automobile(s): 97 STS
    Feb 2006
    Norcross, GA
    35
    37
    Quote Originally Posted by gary88
    I have a 97 STS and I do not see theses buttons you are talking about. The only buttons I see relevant are the ones at the top of my middle console which are "Trip Reset" "Info Reset" "Info" "Fuel Door" "Trunk". What do I need to do to get codes for my car?
    jkindley is offline Cadillac Owners Member
    Sep 2004
    Norther California
    46
    On a 97 STS press the Off button on the Airconditioner and the Passanger Warmer button at the same time. The IPC will cycle through all of the codes and then allow you to do things to the onbord computers. Press the Auto button to switch back to normal.
    Jim
    youngrudy's Avatar
    Feb 2006
    Norcross, GA
    35
    37
    Quote Originally Posted by jkindley
    Jim
    Ok. I was able to pull these codes and research the meaning and this is what I got...
    PCM 0404 History - EGR control circuit out of range
    IPC B1910 Current - Generator L - Terminal Open Circuit
    ACM B1347 Current - Very Low Refrigerant Warning
    ACM B1348 History - Very Low Refrigerant Pressure
    PZM B0533 History - Fuel Sensor Open/Shorted to B+
    PZM B1552 History - Keep Alive Memory (KAM) Error
    PZM B1558 History - BCM EPROM Checksum Error
    PZM B1971 History - Inadvertent Power
    PZM B2470 History - Cellular Phone Antenna Circuit (2000+)
    PZM B2471 Current - Interior Lamp Fault
    PZM B1983 History - Device Power Circuit Low
    PZM B2473 History - High Beam Fault
    I put the current ones in bold because I assume they are current problems and the history ones are past problems (if not please let me know). Now of the current ones I am aware of all but IPC B1910. What does this mean, and how do I erase the codes? At the end, all that appeared was "PCM?". Also for B2471, how can this be fixed?
    mikepines is offline Cadillac Owners Member
    Mar 2006
    22
    I am interested in this also. I, too am new to the boards. Thanks for the info on getting the codes. All of my codes had the word history after them. What does that mean? I am here to try to troubleshoot the stabiilty reduced problem on a 1997 sts.
    Thx.
    Mar 2006
    22
    Ok, I figured it out thanks to the great posts on here and cleared all the codes out.
    Thanks Ranger.
  12. Remove Advertisements
