97 Eldorado.. How to change the rear spark plugs ?
Results 1 to 10 of 10
Cadillac Seville / Cadillac Eldorado Forum Discussion, 97 Eldorado.. How to change the rear spark plugs ? in Past Cadillac Vehicle Discussion; hi guys, i wanted to check out my spark plugs on my 97 eldorado. i can see how to pull ...
    kevinrea is offline Cadillac Owners Fanatic
    Aug 2005
    166
    hi guys,
    i wanted to check out my spark plugs on my 97 eldorado. i can see how to pull out the ones in the front, but how the heck do i get to and pull out the ones in the rear of the engine block ?
    thanks,
    kevin
    69
    82,383
    Re: 97 Eldorado.. How to change the rear spark plugs ?
    Remove the strut cross brace. Removing the ICM and setting it aside will give you lots of room, though it is doable without it. Then pull the plug wires. It's easier than it looks.
    jkindley is offline Cadillac Owners Member
    Sep 2004
    Norther California
    46
    I changed my plugs last year and it was quite easy once the coil pack was removed. Make sure when you put the coil pack back in that you don't pinch one of the spark plug wires.
    Jim
    57eldoking's Avatar
    57eldoking is offline Cadillac Owners Member
    Automobile(s): 57 Eldorado Biarritz, 57 Eldorado Seville, 94 STS, 95 FWB
    Feb 2004
    Lillestrom, Norway
    31
    46
    I just did it two days ago on my 97 Seville. Its easy, just remove the coil pack and you will have more than enough room.
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    A real spark plug socket with the rubber insert to grab the plug instead of a reguler socket is real handy too.
    69
    82,383
    Quote Originally Posted by EcSTSatic
    Good point. Mine did not have the rubber insert to hold the plug in the socket. A length of heater hose will work great to get the plug started if your plug socket does not have the rubber insert. Just stick the plug in the hose and use it as an extention to start the treads.
    Aug 2005
    166
    Ok..What spark plugs do you guys recommend for a 97 eldorado ?
    make an model of plug ? and what gap ?
    thanks,
    kevin
    69
    82,383
    AC Delco 41-950
    Gap to .050
    STS 310's Avatar
    STS 310 is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 STS
    Dec 2003
    LOS ANGELES CA
    1,489
    Quote Originally Posted by Ranger
    AC Delco 41-950
    Gap to .050
    Exactly.
    OEM all the way. Dont be swayed and stick with what came with the car
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    You shouldn't regap the platinum plugs, they should come out of the box at .050. On my ETC I didn't move anything except the silver beauty cover... coils and strut tower brace stayed put. It was fairly easily actually, just had to use one extention.
  13. Remove Advertisements
