Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: bench test a starter?
    Sep 2003
    46
    is there any way to bench test a starter to see if it is good?
    Thanks
    Kev's Avatar
    Kev is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1989 Sedan DeVille is now just a fond memory ....
    Aug 2004
    Left Coast (Central)
    57
    10,427
    Re: bench test a starter?
    I think so, I would call your local parts stores and see if they will do it for you.
    Jan 2006
    SE Michigan
    198
    Around here Autozone and Murrays both have testers that check all aspects of staters and alts.
    Rich
  5. #4
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    The parts stores will test it but it's not under a load. You could do the same with jumper cables and a starter switch (just a push on/let up off heavy duty switch).
  6. #5
    69
    82,272
    I've done it without a switch. Just touch the jumper cable to the positive cable solenoid lug.
  7. #6
    Jun 2005
    High Desert, South California
    442
    I have a question about Norstar engine starters, is it true the engine has to be removed in order to remove the starter? I was told this by folks that did my radiator job.
  8. #7
    Sep 2003
    46
    Thanks for the info guys, I just removed it and tested it It all works fine on the bench. To get to the starter on my 94 sts I had to remove the intake manifold it is under there. not as hard as it sounds.
    Heres a question tho, after I tested the starter and the drive, and reinstalled it It still just spins, at least thats what it sounds like, and the motor does not turn anyone have any Ideas? could there be a problem with the gear that the starter conects to that turns the crank? it doesent seem to me like it would be a part that would break
  9. #8
    69
    82,272
    Quote Originally Posted by rfishing
    They obviously know nothing about the Northstar. The starter is under the intake in the valley.
  10. #9
    69
    82,272
    Quote Originally Posted by kennydawgg
    When you bench tested it, did the pinion just spin or did it move to the rear and then spin?
  11. #10
    Sep 2003
    46
    it moved to the end, and i tried to move the gear around the shaft. locks in one direction spins in the other
  12. #11
    69
    82,272
    So when you bench tested it, the pinion moved to the rear but did not spin?
  13. #12
    Sep 2003
    46
    no, it spun after it moved out
  14. #13
    69
    82,272
    Hmm, that's strange. Just the way it should. Not sure why it won't do the same when in the car.
  15. #14
    Sep 2003
    46
    I know its kinda agravating especially when it happened at the same time my tranny went in to neutral when I was driving, So I don't know if they are related or a coincedince but it is frustrating.
  16. #15
    Sep 2003
    Arizona
    3,531
    It's possible the one way clutch is slipping under load. It'll feel good by hand but slips when it tries to turn the engine. You can replace just that part but it can be hard to find.
    The gear on the flex plate can get damaged teeth. If you take the starter off again look at them.
  • You may not post replies
