2003 Northstar Engine Cover
Results 1 to 12 of 12
Cadillac Seville / Cadillac Eldorado Forum Discussion, 2003 Northstar Engine Cover in Past Cadillac Vehicle Discussion; Greetings I've been looking at the cover on my engine and it does not sit straight. Kind of tilts down ...
    roadie389's Avatar
    roadie389 is offline Cadillac Owners Member
    Automobile(s): 2003 Seville STS
    Dec 2004
    63
    Greetings
    I've been looking at the cover on my engine and it does not sit straight. Kind of tilts down as if moves toward the passenger side of the car. I took it off the last time I cleaned the car to clean the under cover and intake runner area. Did I lose a spacer? Or does it just sit like that?
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Re: 2003 Northstar Engine Cover
    I don't think there are spacers. There are just the studs that are molded into the intake that holds the cover on. Did one of the studs loosen up and let one side sit high?
    the727kid is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC & 1994 Pontiac Firehawk
    Jan 2006
    St. Pete, FL
    27
    1,158
    Your did you tighten all of the screws fully?
    roadie389's Avatar
    Dec 2004
    63
    Quote Originally Posted by the727kid
    Yeah, I looked at it again today. Took the cover back off and It does not make sense. All the nuts are tight. Everything looks right. Oh well.
    gary88's Avatar
    gary88 is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2007 E92 BMW 335i
    Nov 2005
    Chicago, IL
    28
    10,760
    I did the same thing today when cleaning under my hood. Mine sits perfectly flush. Did you make sure the two rods in back are also in the holes?
    SL1CK's Avatar
    SL1CK is offline Cadillac Owners Enthusiast
    Automobile(s): 1996 Cadillac Seville STS
    Jun 2005
    Houston, TX
    28
    535
    Mine sits a bit tilted too, but its because the top right nut is not on...its a pain in the ass trying to get it onm...so i didnt put it on..
    97DevilleConcours is offline Cadillac Owners Member
    Automobile(s): 2003 Deville LD8, 2007 STS V8 AWD
    Apr 2012
    Toronto, Canada
    31
    35
    I have a 2003 Deville that did not come with an engine cover. I just purchased one from EBAY that did not come with any nuts/bolts. What type of bolts/nuts do I need to fasten it with? Thanks!
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Well the stock "nuts" are just black, plastic pieces with threaded inserts. They'd be really cheap at a salvage yard. I'm not sure what the thread pattern is.
    7 year old thread, not bad.
    Apr 2012
    Toronto, Canada
    31
    35
    I found a picture of them on EBAY for the 90s series N*'s. They look like 10 MM retainer nuts. I'll just try the dealership. Thanks.
    Sep 2010
    East Boston MA.
    29
    26,325
    The plastic "nuts" are bigger than 10mm, but yeah, a dealer will have them.
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    They are 13mm
    Submariner409's Avatar
    Submariner409 is online now If it won't run, install a boombox
    Feb 2006
    MD Eastern Shore, Kent Island
    56,568
    ............. and DO NOT get carried away with the socket wrench - strip out that metal insert and you're gonna have a fun time getting the cover off again. Just a tad more than finger tight is all it takes.
  15. Remove Advertisements
