Window Problem Heeeelp
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, Window Problem Heeeelp in Past Cadillac Vehicle Discussion; Hello, the driver window on my 97 eldorado wont go up or down... at first i put it down then ...
    da17 is offline Cadillac Owners Member
    Oct 2005
    56
    Hello,
    at first i put it down then up, when it reaches the top i hear a grinding sound.. i tried to pull it up and down continously and then it stopped working.. im sure the switch is fine.. could it be the motor? could it just be out of place? i did play with the window a little to see if it was.. how much is the motor for the window.. and anyone know how to replace it if that is the problem... thank you
    elwesso's Avatar
    elwesso is offline Cadillac Owners Master
    Automobile(s): 2005 CTS-V, 1994 Infiniti Q45
    Jan 2003
    Indiana
    7,668
    Re: Window Problem Heeeelp
    sometimes the switches go bad, but likely its either the motor or regulator.
    MacKiNBacK's Avatar
    MacKiNBacK is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 Seville STS
    May 2004
    Chicago Area
    33
    687
    Id go with the regulator. Had a few go on me but were covered under warranty. Grinding sound is what I heard. But I wouldnt mess with it too much. I did that and then the window just fell and had to be taped up untill it was fixed.
    MacK
    NickySantoro is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Eldo 4.9 66K miles
    Nov 2005
    Nazi Jerky, libtard central
    368
    That grinding sound is likely a stripped gear drive in the motor/ drive combo. Easy repair after you get the door panel off. Lube the regulator before reassembly in case a binding regulator was the cause of the gears stripping. You can get them on Ebay for a reasonable price or you can buy from the dealer for about triple. Your call. You'll need a manual. The much and fairly criticized Chilton manual actually does a good job with this.
    BTDT
    FWIW
    YMMV
  7. Remove Advertisements
