Trouble Code Hell!!!
Results 1 to 4 of 4
Cadillac Seville / Cadillac Eldorado Forum Discussion, Trouble Code Hell!!! in Past Cadillac Vehicle Discussion; Hey guys, newbie to this forum. I'm trying to fix my father-in-laws 95 STS before I sell it for him. ...
    felo72 is offline Cadillac Owners Member
    Feb 2006
    1
    Hey guys, newbie to this forum. I'm trying to fix my father-in-laws 95 STS before I sell it for him. I pulled the codes tonight and about fell over because of how many there were. In order to get the codes, I also had to remove the battery and charge it for him. I've gotten the definition for every code, and started to look up the fix for some, but wanted to get some opinions if I fix one, will another go away? Any help you guys could give would be great!
    I032- Loss of ABS/TCS Data (???- how do I get this back?)
    I052- Keep alive memory error (???)
    P036- EGR valve pintle position out of range
    P052- PCM memory reset (???)
    P056- Transmission input speed sensor
    P061- Cruise vent solenoid problem
    P109- Keep alive memory - reser/PCM has lost primary battery power (???)
    P137- Loss of TCS data (???)
    How do I get the TCS or PCM memory problems fixed?
    Thanks in advance,
    Chris
    Trench's Avatar
    Trench is offline Cadillac Owners Fanatic
    Automobile(s): 1991 Eldorado (Gone) ; 2001 Seville SLS (RIP) ; 2005 DeVille
    La Salle County
    32
    228
    Re: Trouble Code Hell!!!
    Do the codes Say "CURRENT" or "HISTORY" after them?
    If they say history then there is little need to worry. Especially since you removed the battery. Doing so can cause a whole slew of codes to be throwed. They all go to History, though.
    I think I had roughly 20 History Codes after my battery died.
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Could be from the battery dieing... but i doubt it... Probably something wrong with the connection.
    This one's from pulling out the battery. Don't worry about it.
    This thread should help: http://www.cadillacforums.com/forums...egr-valve.html
    Also from pulling out the battery. Don't worry about it.
    This is one to look into. It's probably not from pulling out the battery.
    Could be from pulling out the battery, but i doubt it. probably the connection
    I personally dont look at if the codes are History or Current, because despite that label, it was a problem at one point in time, and it should be inspected either way.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    When battery voltage goes low it throws false codes. How many?...varies each time. The changing of the battery should have cleared them all but it didn't.
    They are meaningless. The sensors see the low voltage and think they have a problem. The only problem is the low voltage from the battery.
    Clear them, drive the car and see if any reset. Those will have meaning.
  7. Remove Advertisements
