Best exhaust combos for best HP and sound
Results 1 to 7 of 7
Cadillac Seville / Cadillac Eldorado Forum Discussion, Best exhaust combos for best HP and sound in Past Cadillac Vehicle Discussion; I have a 1996 STS and I was wondering what HP advantages I would see from a cat back system ...
    club car's Avatar
    club car is offline Cadillac Owners Member
    Automobile(s): 1996 Cadillac STS
    Aug 2005
    Canada Ontario
    29
    85
    QuestionBest exhaust combos for best HP and sound
    I have a 1996 STS and I was wondering what HP advantages I would see from a cat back system or a Down pipe back or headers back exhaust systems.
    Thanks
    danbuc's Avatar
    danbuc is offline Cadillac Owners Connoisseur
    Automobile(s): '87 Jeep, '10 Thruxton, '00 Duc 748, '01 748R (853cc)
    Mar 2004
    Mahwah, NJ
    31
    3,703
    Re: Best exhaust combos for best HP and sound
    Well, considering there's no room for anything other than a cat-back system, I've heard good result with custom 2.5 inch systems using mufflers such as Dynomax, Magnaflow,...ect. you might see anywhere from 5-10hp gain I guess. These cars do tend to wake up a little with a less restrictive exhaust system.
    SL1CK's Avatar
    SL1CK is offline Cadillac Owners Enthusiast
    Automobile(s): 1996 Cadillac Seville STS
    Jun 2005
    Houston, TX
    28
    535
    What about with a K&N filter?
  5. #4
    danbuc's Avatar
    Mar 2004
    Mahwah, NJ
    31
    3,703
    Completely useless. You might as well just stick a rubber plug in the TB and be done with it. All the K&N filter does for the Northstar is weaken it's bottom end torque, and eventually clog the MAF sensor with oil.
  6. #5
    mtflight's Avatar
    mtflight is offline Cadillac Owners Connoisseur
    Automobile(s): 1999 White Diamond ETC
    Jan 2005
    Dallas, TX
    2,538
    Quote Originally Posted by club car
    Thanks
    Here's what our insider once said:
    Quote Originally Posted by retired resident expert
    In all honesty the real cork will ultimately be the production exhaust manifolds and the "cross through" pipe that goes from the front bank to the rear bank to route the front bank exhaust rearward. The production parts are packaging-constrained and designed for emissions performance to light the catalytic converter quickly. That being said, they are not THAT bad... But the real hotrod Northstars like CHRFAB is putting into sand rails and such run headers.
    I would go with 2.5 to 3 inch pipe from the cat rearward. It will have to be a custom bent setup as I don't know of any avialable sources for the prebent parts. Several people have tried different brand mufflers for low backpressure. Flowmaster, Corsa, etc... You'll have to do some searching in the archives for their reports on sound quality and noise. They will definitely be louder but probably tolerable.
    There's really no practical way to put real exhaust headers on the transverse mounted Northstar engines due to space, packaging and routing constraints. The idea of a "free flow" exhaust sytem is not lost on the engineers that designed the production car... but... packaging, lack of space, the cross-thru pipe design, emissions performance, durability of the exhaust manifolds and system, etc... All got in the way of real headers...
    One thing that will help free up a few horse power is to get the exhaust manifolds off and have them extrude-honed. There are a lot of sharp edges and corners in the fabricated manifolds that can be ground, smoothed and radiused. Not a huge gain here and a lot of work to pull the manifolds and such but if you want the most power, the manifold rework with the low backpressure system will provide the most. I would say that the ultimate exhaust on a transverse passenger car with extrude-honed manifolds, large pipes and Flowmaster style muffler would probably provide 20-25 HP at peak power.
    As danbuc stated, the cat-back is about as much as you can do. You can additionally get a high-flow catalitic converver, which will also increase the sound a bit. Magnaflow makes one that fits perfectly.
    BTW, removing the resonator does nothing but make the exhaust louder.
  7. #6
    club car's Avatar
    Aug 2005
    Canada Ontario
    29
    85
    thanks guys im now not thinking that I might just leave my car stolck. thanks guys. when my orignal gets roted or somthing then i will think of it thanx guys
  8. #7
    mtflight's Avatar
    Jan 2005
    Dallas, TX
    2,538
    95+ is stainless steel--it will last virtually forever.
  9. Remove Advertisements
